Ferris wheel
Ferris wheel
Home › Forums › General Questions › Ferris wheel
  • #147204
    Tom Buckley 1
      @tombuckley1
      Hi guys i wounder if some kind person out there might be able to help me out as i not got a clue on where to start sad i would like to make a Ferris whee on my cnc machine but not sure where to start as i am quite new to cnc ing dose any one have a set of dfx file that i can look at or use to help me out please thanks you to you if you can Tom
      #23203
      Tom Buckley 1
        @tombuckley1
        how to make
        #147217
          Is that a fairground Ferris WheeL or a Ferris WheeL clock?
          J
          #147238
          Tom Buckley 1
            @tombuckley1
            hi it's a fairground Ferris WheeL that i was after making
            #147319
            russell
              @russell
              you may get some inspiration from looking at meccano models of ferris wheels – there are big ones and little ones, some with plans and some just photos/videos – but fundamentally they are pretty simple.
              -russell
              #147352
                Welcome Tom,
                Do you have a full-size example that you'd like to copy, or an idea of the size you want to build?
                Tom Buckley 1
                  @tombuckley1
                  Hi Neil thanks for getting back to me the size of the wheel i would like is about 550mm it's a sweet stand for my wife here is a pick of what i like to make http://www.polka-dotchaircoverhire.co.uk/fabulous-ferris-wheel/ thanks Tom
                  #147551
                    HI Tom, I think redesigning it so it's all flat plates that can be held together with adhesive would be one way to go. That way you only need 2D cutting.
                      As its such a styalized ferris wheel I think you will be better off drawing out your own with CAD that way you can check that the trays won't hit each other as it revolves.
                      If you have a sheet metal option on your Cad the trays could be folded from a flat sheet
                      Also what happens when someone takes a big hand full of the ones thay like and the tray gets lighter as then the opposite heavy tray will always drop to teh bottom?
                      #147591
                      Robbo
                        @robbo
                        Adjustable friction pads on the spindle?
                        Edited By Robbo on 21/03/2014 09:17:50
                        Edited By Robbo on 21/03/2014 09:18:20
