Hi Barry,
That was the only thing that made sense, the lever has been re attached ‘kift’ as we say down here. If you have a lot of slop in it then yes, the pad may be missing.
I just had to re read what you were saying about the cross slide after Bernards comment.
So in normal operation, gearbox feed from headstock in forward gear (headstock lever), lead screw disengaged and power shaft speed suitably selected and rotating normally, the turning / facing plunger on the apron is in the fully pulled out position – when you engage the power feed worm box the carriage travels towards the headstock (as it should).
With nothing else changed except the turning / facing plunger on the apron is pushed all the way in through neutral to facing, your saying the cross slide travels Outward towards the operator?
That I cant get my head round, I cant see how that is possible on that apron. Very odd.
Possibly daft question time, sorry, but you aren’t using 2 different levers on the apron for turning and facing are you?
