Facing off on Sherline
Home Forums Beginners questions Facing off on Sherline
  • #425765
    Chris TickTock
      @christicktock
      OK Guys basic help needed and want to get it right. So I wish to face off the end of this hex bar. My inclination is to turn the cutter a few degrees and take fine cuts. If I am right how many degrees is usual.I am using a cutter which my book states can be used to face as well.
      regards
      Chris
      #9818
      Chris TickTock
        @christicktock
        #425768
          try 5 degrees between cutter and finished end of work.
          A photo of your cutter in the toolpost would be a big help
          #425770
          Chris TickTock
            @christicktock
            Posted by JasonB on 24/08/2019 14:15:08:
            Thanks Jason worked fine at slightly more than 5 degrees.Question would it damage the cutting edge or cause other issues if more of an angle was tried?
            Chris
            #425771
            Chris TickTock
              @christicktock
              #425774
              Jon Freeman 2
                @jonfreeman2
                I would face this with far less of it protruding from the chuck. Angles look about ok
