Just to put the record straight, Ellisons never bought Andertons. Andertons belonged to an American parent company who owned a number of fastener companies and they bought Ellisons. The two companies where then "amalgamated" on the existing Ellison site, the Anderton site in Bingley was disposed off.
The idea that any of the product manufactured at either site was of suspect quality may have been true in the 60's but they both supplied direct into automotive (tier 1 suppliers) so quality was always paramount. Traceability has been a requirement for automotive suppliers for a long time and you just don't supply unless you can prove history right back to the ladle.
Circlips are not all produced from strip like washers. Rings with an ID of roughly 30 mm ID (either internal or external type) are made from strip material but bigger than this and they are normally made form wire stock that is coiled into a ring and then blanked to give the required form.
As Ian noted, the parts are all treated to remove any detachable burr in a "barreling" process that removes them and produces a much more uniform edge condition. If you have rings that have obvious and visible large radius on one side then they are cheap imports that are non-compliant with the accepted standards – they probably did not originate in the UK or any place near!
The idea that the "best" quality are all ground is also erroneous. This is an expensive process and is reserved for items that require either a sharp corner or most often a specific tolerance on the thickness that cannot be obtained any other way. Wire stock parts do not have a sharp corner on either side – they are the same both sides and there is an allowance for the ring maximum corner radius that is taken account of in the design of the ring and the specification of the groove. This is quite an in-depth design process and takes account of a number of variables.
Finally, anyone who thinks they are just nasty cheap little things designed to disappear under the nearest immovable object as soon as you try and use them are badly mistaken. They are as highly engineered as anything else in industry and are made to the highest standards. They are often required to perform the most demanding of jobs in arduous conditions and expected to work after "thugs" with screwdrivers or whatever else is to hand, rive them off and then hammer them back on!
And you thought it was just a case of making a bit of a groove on the end of the shaft and slipping a circlip over it. You all know a little better now
PS. That is the abbreviated version – there is significantly more to it than that.
