Etching Aluminium
Etching Aluminium
Home Forums General Questions Etching Aluminium
Viewing 8 posts - 26 through 33 (of 33 total)
  • #549582
    ChrisB
      @chrisb35596
      I have used hydrofluoric acid to etch aluminium at work, but only because it was a process requirement. I would avoid it if there were alternatives as it's one of the worst chemicals one can handle, so much so that apart from al the necessary ppe we also have a specific first aid kit with antidote for paramedics in case of an accident. Exposure effects of HF can be delayed, leading to severe injuries.
      I would suggest electo-etching. Chromic acid might work, but it's an anodizing process rather than a etching one, so you will get a golden brown contrast without taking away any of the parent metal, but I believe it works only on alloys of aluminium.
      Andy_G
        @andy_g
        I know this is an old thread and Neil has probably sorted his etchings out years ago, but since it has come back to life, I can confirm that ferric chloride works well. My stuff has also been used to etch a small amount of copper which may/may not matter.
        Edited By Andy_G on 13/06/2021 11:04:57
        #549593
        Robin
          @robin
          Posted by ChrisB on 13/06/2021 10:26:35:
          In the days before H&S schoolchildren were invited to etch glass at home using HF extracted from teeth secret
          #549594
          Andrew Tinsley
            @andrewtinsley63637
            For what it is worth, most etch primers for aluminium contain phosphoric acid as the active ingredient. Being a cheapskate I usually prime aluminium with phosphoric acid and then just paint with any old paint. It seems to work well as the oldest aluminium to have had this treatment is 30 years old now, with no sign of peeling.
            Andrew.
            #549698
            Graham Stoppani
              @grahamstoppani46499
              In a previous life I was Managing Director of Turco Products Ltd. manufacturers of etchants and maskants for the aerospace industry. A process we called 'chemical milling'.
              Googling Turco and Chemical Milling will bring up a fair bit of information for you Neil.
              The etchants had a basic ingredient of caustic soda with a number of additives. (In a similar way a plating bath has additives to modify the basic chemistry for a better finish). The maskants were made from a mixture of toluene, rubber and chalk.
              Can I second the warning to keep well clear of hydrofluoric acid. The pills referred to are to replace the calcium that this leached from your bones and we instructed staff to start taking them straight away if they came into contact with the acid. Nasty stuff. The rare times we used this in our manufacturing process the operatives had to wear full haz mat protection.
              #549705
              Nicholas Farr
                @nicholasfarr14254
                Hi, hydrofluoric acid is indeed nasty stuff, it will dissolve glass, burn through your skin and attack your bone before you feel it and the vapours will damage your lungs in a relatively short period of time. Don't use it unless you understand how to use it and dispose it safely and using proper full PPE which you can shower/wash off before removing.
                Regards Nick.
                #549861
                  Posted by Andy_G on 13/06/2021 11:04:20:
                  Beautifully done Andy. A compressor I see
                  Andy_G
                    @andy_g
                    Thank you very much! (Well spotted! smiley )
                    Edited By Andy_G on 15/06/2021 13:12:28
