Engine plans
Engine plans
Home Forums General Questions Engine plans
Viewing 25 posts - 1 through 25 (of 29 total)
  • #365980
    Ian McVickers
      @ianmcvickers56553
      Hi all, I've just picked up a copy of Ray Hasbrouck's Steam Engines. The dimensions are in that old imperial stuff that us young 50ish ones don't really work with. Is there a set of drawings around for his No 3 engine in metric? If not I'll just have to sit in front of cad for a while and convert them.
      Ian
      Ian McVickers
        @ianmcvickers56553
        #365998
        ronan walsh
          @ronanwalsh98054
          Why not use imperial and learn a new skill, nothing wrong with imperial, beats that nasty french metric hands down. I did this with a project, good imperial tools are very cheap, and dro's can work in both metric and inch.
          #366018
            You may want to take a look back through the "Workshop Progress Thread" as Jim Nick has recently completed the same engine and altered some of it to metric. Finished engine part way down this page some earlier posts show its progress
            As it is not a big engine a simple conversion is to allow 1/32" on the drawing to equal 1mm which makes it a bit bigger but you will end up with whole millimeters rather than many decimal places.
            This means you don't have the need to decide to increase or decrease a stock size to a nominal metric one. For example if the part is a 3/32" threaded shaft you can simply use 3.0mm dia stock and be able to thread it M3 rather than deciding what to do about threading a 2.381mm diameter.
            #366039
              Posted by ronan walsh on 06/08/2018 22:06:06:
              … nothing wrong with imperial, beats that nasty french metric hands down…
              Hurrah, we're off!
              Imperial is fundamentally wrong because it's internally incoherent. On top of that it's stuffed with complicated artificial relationships between units and sub-units, for example, there are:
              • 437½ grains in an ounce
              • 16 ounces to the pound
              • 14 pounds in 1 stone
              • 7.142857 stones in 1 hundredweight
              • 20 hundredweights in 1 ton
              Although individual members are cuddly, the Imperial family is dysfunctional. Taken as a whole, the Imperial system is a mess. When the Imperial system is applied to scientific and engineering calculations, everything still works, but the inconsistencies hurt. Formula are less understandable and using them error prone.
              For simple work Imperial is often convenient, like being able to divide 12 by 2, 3, 4 and 6. Unfortunately, that convenience turns into a disability once you get beyond straightforward problems like sharing out cake. When the maths is difficult, the Imperial system has no fans.
              Related issue with fractions versus decimals. If you live in a world where most things divide neatly ½, ⅓, ⅛ etc, fractions are a good idea. Calculating Gear ratios is an example. But it's a bad mistake to imagine that fractions extend naturally to other problems, they don't. It doesn't take much complexity in a calculation for the advantages of decimal to assert themselves : as a system, decimal is more general than fractions, which is why fractions rarely appear in the metric system.
              The only reason Imperial survives is the number of people steeped in it. Doesn't mean it's a good system. Much dafter ideas than Imperial have lasted centuries because millions haven't had the time, effort or desire to change.
              Jim Nic
                @jimnic
                I did buiild my version of this engine in Jason's link using metric units but while converting I reduced the size because to my eye the engine was a bit long with not a lot of moving bits going on . I used a photocopier, a calculator and some Snopake to arrive at my working drawings, no CAD to share I'm afraid.
                Jim
                #366046
                Mick B1
                  @mickb1
                  Posted by SillyOldDuffer on 07/08/2018 09:48:55:
                  Hurrah, we're off!
                  Think you got US contamination there. An Imperial hundredweight is 112 lb, or 8 stone.
                  Oh, and there's been some study a few years back that showed people adept at Imperial calculation are more flexible at mental arithmetic than those who just shuffle the decimal point back and forth… laugh
                  Edited By Mick B1 on 07/08/2018 10:10:45
                  #366064
                  colin hawes
                    @colinhawes85982
                    Having many imperial tools and old but excellent imperial machines I naturally welcome imperial drawing dimensions but I have had to work professionaly with both systems so I really am not bothered by mixing them when making things. A lot of what I do now is restoring parts of vintage motorbikes which are generally measured in inches anyway. I do have a metric micrometer, digital calliper and a DRO so conversion is easy anyway. Incidentally , what's imperial weight got to do with machining things? Colin
                    #366074
                    Brian G
                      @briang
                      Being able to work in metric and Imperial (which normally requires both fractions and decimals) is useful in a hobby where so many designs, as well as the prototypes from which they are derived, were originally in imperial or US customary units. It is also quite a stimulating exercise after a career which has been almost entirely metric, even if it has often involved materials such as extruded angles 25.4 x 12.7 x 1.6mm, or getting very upset at people who put 1/4 Whit nuts into a bin of M6.
                      In some drawings Imperial or BA threads are used with metric dimensions. This is particularly common in 16mm/ft models, but hard to complain about given the scale ratio and in other cases either metric or imperial materials are hard to find. My mental arithmetic is far too slow for this, so I have made and laminated sheets showing 64ths/thou/mm and refer to them frequently.
                      #366083
                      colin hawes
                        @colinhawes85982
                        When I was working as a toolmaker fractional dimensions were only used for an unimportant dimension such as the base of a drill jig and had a tolerance of +/- 1/64 th of an inch. Apart from standard threads, everything else was dimensioned decimally anyway, normally in "thous", e.g. 1.002, often in "tenths", e,g, 1.0002, so it was very similar to metric dimensioning apart from the basic unit of one inch as opposed to one millimetre.
                        #366084
                        duncan webster 1
                          @duncanwebster1
                          Why don't fraction-o-philes have micrometers which read in 1/1024" (the logical progression from 1/2, 1/4 etc)? Simple answer because fractions are extremely unwieldy when you get beyond simple stuff. This from someone who started out bi-lingual in cgs and Imperial, but for the last many years of employment used only SI for calculations because it's less prone to errors introduced by the wierd 32.2, 384, 770, 550 factors which you have to remember. As for someone brought up in metric being encouraged to learn fractions, let's get real. If young people are to take up model engineering they are not going to learn a new illogical language.
                          #366085
                          Andrew Tinsley
                            @andrewtinsley63637
                            I am amazed that people can take up fixed positions on this topic. I am equally at home with Imperial and metric dimensions and sometimes even mix them together on a drawing!
                            There is nothing difficult in either system. Neither is logical if you delve into them. At this point I will take cover.
                            Andrew.
                            #366091
                            Mick B1
                              @mickb1
                              Posted by Andrew Tinsley on 07/08/2018 12:35:19:
                              Andrew.
                              No need. I think there are plenty of us to give you covering fire… wink
                              #366095
                              Brian H
                                @brianh50089
                                Quoting rubbish like;
                                is to use misleading information to try to make a point.
                                #366147
                                  Hmm.
                                  The advantage of imperial is the 'powers of two' subdivisions make it very easy to design things in good proportion while ensuring small parts can add up to sensible sizes.
                                  In metric you have the choice of powers of ten, which are obviously too big, or using 'preferred sizes' which have the problem of rarely being able to be combined to give convenient larger sizes.
                                  So while metric is much more logical, imperial lends itself to design of mechanisms where you need lots of bits to 'add up'.
                                  Ian McVickers
                                    @ianmcvickers56553
                                    I do work in imperial when required but to me its not a "natural" thing to do. I prefer metric and find it much easier but I suppose its what I'm used to. Most of the machines I work on have various imperial fittings for gas supplies and coolant so that's where I use imperial mostly these days. The exception being one machine where the gas fittings were also metric. That confused the hell out of me for a bit.
                                    #366155
                                      The bane of an editor's life… obviously unavoidable when using certain stock parts, but otherwise…
                                      Trying to change someone's drawing is out, it's too easy to introduce errors that way.
                                        Posted by BDH on 07/08/2018 13:01:22:
                                        No Brian, not misleading at all. You're thinking of the hundredweight of 112lbs that was discontinued as a formal unit 33 years ago. In the US they still have a formal hundredweight but it's 100lbs, not 112. The US hundredweight still has legal currency as a working unit, while the UK hundredweight has joined the farthing as a bygone. Some people know what it was but beyond that it's rarely used in the UK except as a source of confusion.
                                        Interworking with the US, there are 20 US hundredweights in a ton (2000lbs), and there were 20 UK hundredweights in a ton (2240lbs). That's quite a difference, so to avoid confusion the Imperial system still has short and long tons. You have to be careful when doing sums.
                                        I'm afraid the Imperial system isn't just a muddle, it's an international muddle. The case for the prosecution is that Imperial presents like a cuddly uncle, when actually the chap is a liability. Imperial measure is the Harry Worth of metrology.
                                        smiley
                                        Edited By SillyOldDuffer on 07/08/2018 18:48:35
                                        #366188
                                        bricky
                                          @bricky
                                          I have a metric lathe and mill.At present I am building an American design Ic engine in imperial.It is no obstacle to use the caliper in imperial to the drawing dimensions and then press the button to metric,I can't see any problem.
                                          Frank
                                          #366205
                                          ronan walsh
                                            @ronanwalsh98054
                                            I have known very skilled people, Toolmakers, Fitters, Machinists, Cabinet makers, Carpenters, probably more skilled than most around now, who for nearly all of their working life used imperial. They seemed to cope alright. Also you speak as though imperial is dead and buried, its still used in America, and then by people here who work on American products, such as train locomotives, and aircraft.
                                            I worked for years in a hose company, machining threads on fittings, making up hose assemblies etc, all in imperial, usually BSP, British standard pipe.
                                            #366209
                                            Nick Clarke 3
                                              @nickclarke3
                                              Today the only sensible thing to do is to work with metric dimensions because that is what tools and materials are generally available in.
                                              However to talk about a single imperial system is a little misleading as there were many many different sets of units used in different situations – those suitable for a pharmacist making up a medicine were ideal for that but not suited for bags of coal. Similarly the units used by a jewellery maker were not suitable for a manufacturer of steam locos. Despite all of these different sets of units (and more) there was rarely any need to convert between them. Horses for courses.
                                              Along comes the metric system and all of a sudden it is time to try to use a single set of units to cover all of these situations – I say a single set but during my lifetime (and I am not yet retired) I have used imperial units, cgs, mks and SI units in science and engineering. Things are still changing – the most recent I am aware of is the change from 1 kilobyte = 1024 bytes to now referring to 1000 bytes.
                                              Unfortunately the system of units used for most of the history of model engineering was fractions of inches, number and letter drills and gauges for tube, sheet and wire thickness, If these tools and materials are no longer available then yes, you do need to convert – but this trivial using a calculator, provided that clearances and strength of components are not compromised. the original designer might have erred on the tight side for example, and using a standard conversion might be just too much – common sense has its place here.
                                              I have in front of me a drawing by Martin Evans that includes number drill sizes, fractions and decimal inches and it is not the easiest to follow to say the least!
                                              Nick.
                                              PS Recently I tried to show how easy it was in the 1970s when I had to do 12.5% VAT in my head. This was done by working out how many half crowns were in the total sum – it degenerated into confusion when I realised the person I was talking to had no idea what a half crown was. I must be getting old!
                                              #366239
                                              Brian G
                                                @briang
                                                Posted by Nick Clarke 3 on 07/08/2018 22:27:35:
                                                … Things are still changing – the most recent I am aware of is the change from 1 kilobyte = 1024 bytes to now referring to 1000 bytes…
                                                I think it is more like the imperial/customary situation rather than a change Nick. One of my OU tutors was a communications engineer who said in her industry, the IEC base 10 definition has always been used, whilst for programs and RAM the JEDEC base 2 definition remains in use. There were plenty of exercises involving sending 200 MB of data along a 10kb network that made imperial/metric seem straightforward. One thing I can say is that I have not yet met anybody who referred to kibibytes.
                                                #366244
                                                  Posted by Brian G on 08/08/2018 09:59:46:
                                                  Agree with Brian that base 10 and base 2 definitions for data have been around for as long as I can remember. Both have merits, the problem being when they are inadvertently mixed. Base 2 is best used for parallel data in a binary computer because the machine works in base 2. Base 10 is more helpful when the same data is in serial form. The fun starts when parallel computer data is streamed to a serial device like a network or disk drive. The difference is also, a glorious opportunity for salesmen. Quote disk capacity in base 10 and the available storage becomes magically bigger!
                                                  I haven't met anyone who actually talked kibibytes, but they do pop up as in this example from my Linux system resource monitor:
                                                    I've mentioned this before, but it's maybe worth repeating:
                                                    The digital scales that we all know [and mostly love] are binary based
                                                    Have a look at a post on this thread : **LINK**
                                                    http://www.pcbheaven.com/exppages/Digital_Caliper_Protocol/
                                                    At 2 March 2012, 10:30:16 user Hans U. Meyer wrote: …
                                                    ^^^ it's food for thought … Meyer's patent is available via espacenet
                                                      Posted by Mick B1 on 07/08/2018 12:51:24:
                                                      Andrew.
                                                      First of all, let me confess I'm not really the anti-Imperial zealot I'm pretending to be! Please put away your pitchforks.
                                                      That said, making the case for the prosecution, I have to point out that the defence so far consists of:
                                                      • Works OK for me within limited boundaries
                                                      • It's simple
                                                      Neither hold much water. There's an analogy in map making. If I draw a plan of my garden, I can assume the earth is flat because the error caused by the curvature of the earth is tiny. If I draw a map of the whole village, the error is still trivial. Problem solved, or not? This is very like most people's experience of the Imperial System. Provided you stay within it's limitations, they don't matter.
                                                      Unfortunately, like map making, problems appear when you move beyond simple requirements. If I assume the world is flat, my map will be detectably wrong when I'm 10km from home, and it will be badly wrong at 100km, and laughable at 1000.
                                                      The case against the Imperial system is that it doesn't cope at all well with complex problems due to multiple internal inconsistencies. Because its a combination of 'Horses for Courses' systems, it doesn't hang together. As the difficulty of representing the real world with numbers increases, Imperial makes the problem worse, because those horses have to run together.
                                                      This isn't about inches vs mm being used in a workshop. For simple linear measurements, it doesn't matter. Nor does it matter if you think about lifting a lathe in kilograms or pounds.
                                                      Fans of the Imperial system are invited to explore a more difficult example and to share the results. In the metric system (MKSA), the volt is a derived unit. It is defined in terms of Length, Mass, Time and Amperes. In the simplified version of Imperial used for engineering (FPS), what is the Imperial definition of a volt? Once that's been done, what's the relationship between the imperial volt and the Horse Power. Explain how the imperial system has made the exercise easy.
                                                      Now the point is I don't care much what a volt 'is' in my workshop. But I hope it's understood that in engineering more widely, the definition matters very much indeed. The definition isn't arbitrary and volts can be made accurately made anywhere in the world from base standards. Not something you would do in your shed but a real problem nonetheless.
                                                      A further point about the volt, is that it's become part of the Imperial team. Sadly, it's a cuckoo in the nest in that it's not based on Imperial measure. There are other examples.
                                                      Looking into Imperial more deeply, it can't be said to be simple. Long practice may have made it's basic features familiar, but that doesn't mean it's simple once you've scratched the surface.
                                                      If you own an imperial workshop, work on imperial models, and think in imperial there's no reason to change. But please don't believe that Imperial is 'better' than metric, and please don't attempt to foist imperial as a working system on youngsters.
