The reason 4 flute cutters have a tendency to cut oversize is that when one tooth is at the front, cutting sideways, there is a side thrust which will deflect the cutter to the left (looking from behind). A 4 flute cutter will have a tooth at the left, which will cut into the side wall; a 2 flute cutter has no tooth there, so it won't. The "wobble" will also depend on the stiffness of the tool and the depth of cut.
The amount of the deflection will of course vary according to how hard the cutter is being driven forward (the feed rate) and this will vary – even under power feed, it is zero at start and stop. You may get away with it if the slot is open at each end, and your feed rate (and depth of cut) is exactly consistent. Otherwise, not.
I should give credit to G H Thomas for explaining this in one of his books.
David
Edited By David Littlewood on 23/05/2012 11:27:52
