Emma Victoria – Materials
Home › Forums › Model Engineer. › Emma Victoria – Materials
  • #126995
    stephen cooke 2
      @stephencooke2
      I have been considering building Emma Victoria as my next project but i am struggling to locate a source of 5/32 bright mild steel flat for the frames. This is my first attempt at building a loco and i have mainly tinkered with smaller projects up until now and am reluctant to deviate from the drawings. If anyone can direct me to a source i would be greatful.
      #37601
      stephen cooke 2
        @stephencooke2
        #127219
        Mike p
          @mikep
          Hi stephen, I am building this loco and can only recommend as I have done and that is to find a local steel fabricator and get them to shear you some 4mm plate and then if you want it bright sand it to remove the scale. my apologies for the late reply but I have spent the last 4 weeks in hospital without internet access.
          Mike p
          #127227
          john kennedy 1
            @johnkennedy1
            I've used 5 mm plate,because I had some. Adjustments made to the stretchers etc. John
            #127229
              Reeves do some sheared 4mm plate for frames but may be a bit big. Any friendly fabricators, lazer or waterjet cutters should be able to supply a bit of 4mm sheet
              #127244
              Adrian Parker 1
                @adrianparker1
                I would be surprised if anyone produces 5/32 inch steel these days. 4mm should not be a problem however.
                I would recommend Model Engineers laser as he lists laser cut frames for Emma Victoria at a reasonable price but I would suggest that you contact them to check the size he supplies.
                Adrian
                #127245
                S Deakin
                  @sdeakin73134
                  If you really want to stick to 5/32 material Stephen, then try to souce Gauge Plate. This will cut into super frame material as it is ground and stress relived. Buck and Hickman or your local engineers supply company should be able to offer a couple of suitable pieces, though it's not cheap.
                  #127267
                  mike mcdermid
                    @mikemcdermid41977
                    sheffield waterjet have 4mm plate not bright but nicely finished
                    #127268
                      Actually you are better off not having bright bar/plate as it tends to have inbuilt stresses which usually mean it goes bananna shaped when you cut out for the axles.
                      If you want it shiney then look at John's post for how to remove the scale
                      #127378
                      stephen cooke 2
                        @stephencooke2
                        Dear all,
                        Thank you for all your responses they are really helpful. Sadly with 2 children under 3 it may be sometime before I get to make serious inroads into this project but stockpiling materials makes me feel like I am making some progress!
                        #128527
                        HobbyNut
                          @hobbynut
                          Are we going to see any more Emma construction drawings? None in the last 3 issues that I have seen.
                          #128537
                          Diane Carney
                            @dianecarney30678
                            Emma Victoria is back in Issue 4465.
                            There's so much to pack into M.E. these days that sometimes a gap will be longer than ideal. Apologies to all those waiting with baited breath…
                            As Adrian posted above, do check out Model Engineer's Laser – they now have components other than just the frames I believe.
                            Diane
                          Home › Forums › Model Engineer. › Topics
