Emco Compact 5 – Spindle Bearings
Home › Forums › Manual machine tools › Emco Compact 5 – Spindle Bearings
  • #544407
    Robert Bubu
      @robertbubu66700
      Hi all,
      I want to buy replacement spindle bearings for Emco Compact 5, I found 2 kinds: SKF NORMAL CN and C3.
      I would like an opinion, which I should buy?
      Best regards!
      Robert
      #14256
      Robert Bubu
        @robertbubu66700
        Emco Compact 5
        #544426
        Emgee
          @emgee
          Robert
          I used the std bearings in my Emco, didn't want the extra clearance of the C3, use the ZZ not the RS, the latter will cause friction on the spindle and heat the bearing, ZZ is sufficient to keep out any swarf that may find it's way into that area.
          Emgee
          #544438
          Robert Bubu
            @robertbubu66700
            Hi Emgee
            Thanks for the reply
            "I used the std bearings in my Emco"
            Standard bearings are- BEARING CLEARANCE –
            NORMAL CN?
            I'm not good at technical data bearings, so I asked which ones are better
            In the site where I want to buy, there are 2 options:
            6006-2Z SKF
            BEARING CLEARANCE:
            1. NORMAL CN
            2. C3
            So, I choose the option 6006-2Z SKF – NORMAL CN ?
            Best regards!
            Robert
            #544485
            Emgee
              @emgee
              Posted by Robert Bubu on 11/05/2021 14:59:07:
              Best regards!
              Robert
              Yes Robert,
              The SKF 6006-2Z will be fine.
              Check the assembly order in the manual to make sure you get the wavy washer in the correct location.
              Emgee
