ELLIOTT 10M SHAPING MACHINE
Home › Forums › Manual machine tools › ELLIOTT 10M SHAPING MACHINE
  • #556821
    MARK RIGG
      @markrigg57943
      Hello .
      HELP WANTED !
      I am reassembling my 10 M shaper and I have lost the vertical feed screw for the cross slide / table.
      It now looks like that I will have to make a replacement – Does anyone have one of these machines in bits for restoration that could give me a few measurements .
      The thread looks like 3/4“ dia. x 5 tpi LEFT HAND `ACME` . It should also be possible to determine the basic dimensions of the screw in situe .
      Any help here would be much appreciated
      MARK RIGG
      BRIDGNORTH – SHROPSHIRE
      #14321
      MARK RIGG
        @markrigg57943
        LOST VERTICAL FEED SCREW .
        #556838
        bernard towers
          @bernardtowers37738
          Mark , My 10M is a late machine 1976!! so it is metric but still uses imp screws. The vert screw is 11/16 dia x 8 tpi. The dials are marked 3.2 mm per rev which proves the 8 tpi. Hope this is of help.
          #556852
          DMB
            @dmb
            Bernard, how can your machine be classed as metric with Imperial leadscrews? Sounds to me like a ballsup. If it was mine, I would change the dials to 125 divs to make for much easier working. I don't mind working in either system but not what I call half and half. Are the dials OEM? Surely not. No offence intended, just opinion on how to make life easier. John
            #556879
            bernard towers
              @bernardtowers37738
              Sorry but don’t have a problem I can add up and take away as I am over three score years and ten!!
              #556883
              Baz
                @baz89810
                3.2mm is near enough for 1/8 inch on a shaper, it’s only a full thou more per rev. You don’t usually work to Atom splitting limits when shaping, those limits are usually achieved on the Myford👍
                #556884
                DMB
                  @dmb
                  Age – Snap!
                  Edited By DMB on 03/08/2021 17:33:26
                  #556907
                  MARK RIGG
                    @markrigg57943
                    Hello again . First of all , how do you determine if the 10 M is a metric machine ? I can`t find any serial number on my machine , nor any manufacturers plate with a serial number .
                    Also , I have looked at both the cross slide screw and the vertical screw shaft and both dials have 50 graduations .
                    The cross slide screw is 11/ 16 “ diameter and 5 tpi . So , if both graduation dials are the same , can we assume that the vertical feed shaft is also 11 / 16 “ diameter and 5 tpi .? The vertical feed nut ( cut inside the skew gear ) will not screw onto the cross slide screw as I think it is a different hand thread ( L H ? ) . The cross slide screw looks to be a square thread, not an ACME as I first thought .
                    If anyone can run a rule over their vertical shaft and give me some lengths overall and the length threaded portion . The lower portion is plain . That would be very helpful.
                    I would be interested in any further information and comments .
                    Thanks again for your interest …………………..
                    MARK RIGG
                    #556910
                    Robert Butler
                      @robertbutler92161
                      The metric Myford S7 has an imperial leadscrew the handwheel is graduated in metric units, The gearbox if fitted is imperial with banjo and a set of gears to convert to metric pitch. The tailstock, cross slide and top slide have metric pitch feed screws and with metric dials.
                      If the shaper is fitted with imperial screws but the micrometers calibrated to reflect metric measure whilst not ideal it is workable as no doubt many metric Myford owners have found. It is what it is.
                      Robert Butler
                      Edited By Robert Butler on 03/08/2021 19:50:28
                      #556928
                      not done it yet
                        @notdoneityet
                        Posted by Robert Butler on 03/08/2021 19:50:02:
                        Robert Butler
                        My Raglan is the same. Imperial lead screw – metric threads are sorted by change wheels – and feed screws (cross and compound slides) and dials are metric or imperial as required. My lathe is imperial but will soon be metric.
                        Doesn’t make a lot of difference as I’ve already got DROs for long and cross travel indication, the compound mostly only gets altered for facing. Long travel does not use the lead screw as there is a separate power feed shaft.
                        But maybe I should change the imperial trip, for a metric thread, although I’ve never really bothered to count the turns when adjusting it….
                        #556976
                        Brian Wood
                          @brianwood45127
                          Hello Mark,
                          The machine serial number is stamped onto the nose of the ram that holds the tooling slide
                          My 10M is an imperial machine with 8 tpi right hand feedscrews. They are probably of ACME form. The vertical screw dims are
                          17.5 mm [11/16 inch] on the threaded section. The shaft is 15 inches long from the tray to the top of the screw. The bottom of the shaft is 22.3 mm diameter where it enters the bottom bearing housing. That is bolted up from under the swarf tray. The shaft diameter reduces to 17.5 mm diameter at 125 mm from the tray and remains plain for about 30 mm before the screw thread starts
                          I am intrigued as to how you have lost the feedscrew! To remove it from the machine requires some effort, not least grovelling on your knees to remove the bottom bearing bolts. Try looking again for it in some unlikely position.
                          #557096
                          Brian Wood
                            @brianwood45127
                            Hello again Mark,
                            I gave you erroneous information I'm afraid, my feed screws are LEFT hand, not right hand as I stated earlier. Sorry about that but how the change of thread direction helps you much in finding the one you have lost I don't know.
