elliott 00 omnimill
elliott 00 omnimill
Home Forums Help and Assistance! (Offered or Wanted) elliott 00 omnimill
  • #204488
    Manny lambert
      @mannylambert86533
      I am currently renovating an elliott 00, I am looking for the original pulley sizes for the vertical head fitted with a .75hp motor as factory fitted. the manual doesnt mention this?? If any one wants parts, i will be giving them away for free. And any advice on replacing the bearings on the vertical head. Any help would be use full. thanks
      #32572
      Manny lambert
        @mannylambert86533
        pulley sizes for vertical head
        #204522
        Mark C
          @markc
          Manny, I have sent you a message!
          Mark
          #204532
          Cabeng
            @cabeng
            Manny: I got my Omnimill 20 years ago, and refurbished it 15 years ago, when it had to be taken to pieces to relocate it. Then last year (or maybe the year before…or the one before that !) I had the table, sub table and knee slides re-ground and the gibs re-surtfaced with something similar to Turcite. This work was done by Brian Caddy in Nuneaton (http://www.slidewayservices.co.uk) – recommended.
            I replaced the vertical head bearings on my machine only a couple of months ago. Not difficult if you want to use 'ordinary' bearings, you can get away with fairly crude methods of pulling off the old ones and installing the new ones. But the Elliott specification for the nose bearings is that they should be 'matched for back-to-back installation' – unfortunately, when you include that phrase in your purchasing requirements, the bearing price goes up by a factor of 3! £150 for a matched pair, so you wouldn't want to install those using a hammer and drift!
            That means rigging up a better system, and making a few collars, tubes and spacers to ensure that that the races are loaded correctly and evenly during installation on the spindle, and whilst installing the spindle into the quill. I had to make the necessary bits, so if you live in the north west of England, you would be welcome to borrow them.
            The top bearing is a single deep groove ball race, about £25 for a good quality one.
            #204554
            Mark C
              @markc
              "Matched pair", get them swapped for a pair of taper rollers and away you go – that was what I did and it works a treat! Search through my posting history for Elliot Omnimil and you will find the drawings detailing the mods.
              Mark
              #213637
              mick vann
                @mickvann94362
                Hi Cabeng,
                I would be interested in borrowing you bearing installation tools where are you located, I am in Leeds, I already have brought the bearings unfortunately before reading this thread else I would have upgraded to taper rollers. My head is stripped and ready for the bearing installtion.
                I am having to make a new bearing preload nut as the original one had come loose and had been spinning on the shaft and worn away the threads. I dont suppose anyone has the original internal thread size to hand do they ? as I am guessing a little at the moment.
                Regards Mick
                #213644
                Mark C
                  @markc
                  Mick,
                  I have a detailed model of the spindle etc I made when I converted to taper bearings. You are welcome to the model and the drawing if you contact me with an email address so I can send them. When I say detailed, I was bored and modeled the thread form in detail…….
                  Mark
                  #213646
                  Mark C
                    @markc
                    I just measured the model and the thread is 1 & 3/8 by 16 tpi whit form (55 degree). You might need to fiddle the thread diameter a little depending on the exact form you cut……
                    Mark
                    #213927
                    mick vann
                      @mickvann94362
                      Thanks Mark for the info, I will have a go at cutting the thread, I am not bad at making external threads however not realy done internals so do not realy know how much metal to leave for the threads for them to mate to the spindle threads.
                      #213930
                      Mark C
                        @markc
                        I can't remember exactly what the nut looks like but if you measure it up (don't worry about the thread details/internal diameter) and send me a sketch I will draw it up properly and send you a "proper" drawing showing what is needed.
                        Mark
                        #214044
                        Ian S C
                          @iansc
                          When I'm cutting an internal thread I make what ever a few mm longer than finish size, and that few mm I bore to the outside diameter of the male thread, the main bore of the internal thread should be a bit tight for the root diameter. Now just take time , and as you near the outer diameter start trying the thread for fit. Don't know that you can see it, but there is a 32 tpi x about 1 1/2" thread inside the L/H end of the hot cap for a Stirling Engine. Material 316 stainless steel.
                          Ian S CDisplacer hot end,
                          #214047
                          Mark C
                            @markc
                            Ian, that is a damn good idea!
                            Mark
                            #214156
                            Ian S C
                              @iansc
                              Mark, don't blame me if it doesn't work out, I taught myself to thread cut, then read the instructions, they were near enough, the threads were spot on(you'v got to fluke it now and then).
                              Ian S C
                              #215857
                              mick vann
                                @mickvann94362
                                Thanks Ian for the advice on threading, I will give it a go and let you know how it goes.
                                Mick
