Dunlop bearings
Dunlop bearings
Home Forums General Questions Dunlop bearings
  • #26452
    Windy
      @windy30762
      Windy
        @windy30762
        Has any member had dealings with Bearings labelled Dunlop.
        I have just received 6mm and 8mm bore plain spherical bearings for a linkage.
        The outer is split like some other similar small spherical bearings by SKF I suppose so they can press the ball in the outer housing.
        Have found a lot of side play in the Dunlop ones even when I nipped the outer in a collet.
        A small imperial steel on steel spherical plain bearing I was given has less than 8mm bore with a solid outer and shows no play at all in any direction.
        A year ago I bought some 45mm bearing locknuts some were made by Dunlop with very oversize threads compared to some other makers 45mm locknuts.
        When I buy anymore bearing bits and pieces on Ebay will make sure they are not made by Dunlop.
        These part were not expensive so put it down to poor quality control.
        #397711
          All sounds rather disappointing …
          The website tells a good story **LINK**
          http://www.dunlopbtl.com/about-dunlop-btl
          … but that's often the way, these days.
          not done it yet
            @notdoneityet
            Epay are notorious for rubbish. Are you sure your bearings are ‘full spec’ and made in the UK? Could just be ‘labelled’ as Dunlop. A bit like CE labelled items from china?
