Hello all, a few months back, I asked about the electrics on my DSG13/30 lathe, well I have another question, this time about the motor.When I bought the lathe , a new 5 hp TEC motor had just been fitted at the factory that previously owned it and to cut a long story short, had fitted it very badly.Not only sloppily bolted to a bit of plate on 3 spacers, the 4th perched on the lathe bed below the headstock, ???. The drive pulleys were 3/4 inch out of line, but worse, the pulley was loose on the motor shaft.
The new motor shaft size is 28 mm, the old, 1 3/8inch, just over 1/4 inch smaller. Im just in the process of trying to get the mutilated pulley off. It looks like the chap (##ob) sawed 3 inches off the old motor shaft, bored it out 28mm, but oversize !!, bashed it back into the pulley and ploncked the whole lot onto the new shaft, drilling through the " new" reducer, and securing it all with a grub screw. Ive got a nasty feeling that the shaft has been damaged by the pulley being secured axially, but loose.Because he mangled the pulley boss fitting it to the bit of old shaft, its on that bit rather tight !!.Right, to the question, to have saved all this heartache and disgusting language, are there reducers or adaptors available for the changing old motors for new ?. I emailed TEC, but had no reply. Many thanks.
