Hi,
I have a 1936 M Type which I am commissioning. Due to being a treddle machine it appears to have been used very lightly.
I have three immediate queries:
1. Having made up a new clipped balata belt I found the clip was snagging on the flywheel journals and traversing up to the next ring. I adjusted the edge of the clip which fixed it.
I then treddled to test the operation and foolishly engaged the back gear. The bull gear was disengaged, but the shock was enough to break a tooth off the spindle gear and a few off the back gear.
I'm furious with myself, but that doesn't change the fact it is broken.
Does anyone have a back gear and drive gear, to sell, alternatively, has anyone repaired these gears by either letting a tooth in, or welding them up and cutting new teeth?
Can the drive gear be removed from the drive pulley, it appears fixed, but not cast as a single item.
Second query.
I was going to use a treadmill motor to drive the machine, but due to curfew, the treadmill is now in use for it's intended purpose, so intend to use the1425rpm, 1/2hp AC motor I have.
My intention is to drive the original flywheel, probably by the outer ring, but as this flywheel is for a treddle, it has no machining on the outer flange.
The options appear to be to use a flat belt with guides for tracking, or cut a channel in the outer ring…or indeed a ring gear and make it a knee planer.
Is the outer journal crowned and would a flat belt run centrally, without any machining?
Would the flywheel need to be rebalanced if the treddle is removed?
The motor will need a 2" pulley/gear for the speed to be correct. I want to motor to be underslung as space is a premium, but also feel the flywheel will damp any single phase vibrations
Thirdly, if using the smallest flywheel drive pulley to the largest spindle pulley, should one use a second, shorter, flat drive belt, as the length is considerably different.
I could shorten the belt I have made and add a link belt to make it the longer length.
I am a DIY car repairs enthusiast with general fabrication equipment (grinders, welders), but don't have an engineering workshop, so cannt perform my own machining of the gears at present.
Sorry for the long post.
