Driving trolley brakes
Home Forums Locomotives Driving trolley brakes
  • #1983
    Speedy Builder5
      @speedybuilder5
      #510481
      Speedy Builder5
        @speedybuilder5
        Just starting to put pen to paper to design a simple driving trolley for a 5" gauge loco. Thinking of brakes, I want to use bicycle brakes on an axle mounted disc. I am looking at disc type brakes (Cable operated) for simplicity, operating on a smaller diameter disc than its intended for. Anyone have ideas what material to use for the disc. I am thinking of 10 gauge stainless steel at the moment. Also, bike discs are carefully perforated. Is that for cooling ?
        Bob
        #510483
        duncan webster 1
          @duncanwebster1
          There was an excellent design for driving trolley in ME some years ago by a chap called Hudson. No longer with us I fear. It uses bicycle brake blocks on mild steel discs, and I can testify they work, you can stop the wheels going round, at last on ally track, and so you won't get better than that. If you pm me your email I'll send you a copy of the article
          #510502
          Dave Smith 14
            @davesmith14
            My driving trolley (used just for me has a bicycle calliper using brake blocks on a disc just like you are describing. Like Duncan it can lock the wheels even on steel track. The disc is made of ordinary mild steel. Stainless will work just as well. Don't worry about cooling holes or similar you will not be using the brakes enough to warrent them.
            alan ord 2
              @alanord2
              There was an article in Model Engineer March 24th 2000 titled "Low Cost, Low Maintenance Vacuum Brakes" by Peter Gardner. Including design details etc.
              Alan.
              #510522
              Steve Addy
                @steveaddy35670
                I used a couple of vintage centre pull brakes I would have loved to have had as a lad. They work on iron discs of some considerable thickness to emulate a bike wheel rime. They are very effective indeed.
                Steve
              Home Forums Locomotives Topics
