Posted by JasonB on 22/05/2020 10:25:08:
As brass likes sharp cutting tools it may be that your drill that seems OK for steel is not cutting well in the brass and that is making it wander. …
+1. I keep two sets of drills, one reserved for Brass only. Brass likes tools to be sharp, and although I've never bothered, a different rake angle as per Hopper's advice.
Using a drill once on steel can be enough to reduce it's effectiveness on Brass, but drills too blunt for brass still work well on steel. So when I've knackered a steel drill I replace it from the Brass set, and the Brass set gets a brand-new one.
Same with files.
