Dovetail cutting length
Home › Forums › Beginners questions › Dovetail cutting length
  • #464619
    John Brown 18
      @johnbrown18
      Is there a relationship between dovetail cutter diameters and cutting length? Most advertised cutters don't seem to specify the cutting length, Stuart Brown
      #10171
      John Brown 18
        @johnbrown18
        #464623
        John Haine
          @johnhaine32865
          What do you mean by "cutting length"? Looking at e.g. the Arc ones they define a depth of cut, I guess the assumption is that you leave a very small witness of the uncut surface.
          #464629
          John Brown 18
            @johnbrown18
            Thank you, John. Viewed from the side the cutter is a right angled triangle and by cutting length I mean the vertical side of the triangle. I need a cutter which will give me 7.5mm on this vertical side. Arc cutters don't seem to have this depth but other advertisers don't specify it. I really am a beginner. What is a "very small witness"?
            #464649
            John Haine
              @johnhaine32865
              Ok, simple trigonometry says that the base of your right angled triangle will be 7.5 tan 30 which is 4.33 mm. So you need a cutter capable of at least this depth of cut.
              #464651
              John Haine
                @johnhaine32865
                Small witness would be a tiny bit of the vertical surface left.
                #464684
                Howard Lewis
                  @howardlewis46836
                  John Brown 18.
                  4.33 mm is the depth, after the final depth of cut Just in case there is any confusion, it is like eating an elephant, one bite at a time, not all in one!, So think in terms of several passes, taking a little at a time.
                  #464803
                  John Brown 18
                    @johnbrown18
                    Thanks to both. Much appreciated. The trigonometry is the obvious (with hindsight) answer to my question. I'm off to join the village idiots union.
                    #464804
                    Gary Wooding
                      @garywooding25363
                      John, can you supply a dimensioned sketch of the profile of the dovetail you want to cut?
