Does anyone know what this is
Home › Forums › Manual machine tools › Does anyone know what this is
  • #638598
    Les Geds
      @lesgeds96641
      I came across this but haven't a clue what it is.
      #14796
      Les Geds
        @lesgeds96641
        #638599
        old mart
          @oldmart
          With that spring loaded plunger and the gear, it looks like a specialised indexing tool. Some of these tools are specially made for a particular manufacturers requirement and unless somebody has actually used one, the purpose will never be known.
          #638600
          Dennis R
            @dennisr
            Looks like a simple indexing device
            pipped at the post
            Edited By Dennis R on 21/03/2023 20:35:45
            #638601
            Bill Davies 2
              @billdavies2
              Yes, I agree. Given construction, I'd say an amateur made item. Given the relatively small range that the plunger looks to be adjustable, probably just indended for the installed the indexing disc or gear. So, possibly for a specific (repeated) job.
              Bill
              #638608
              RobCox
                @robcox
                I agree with what's been suggested, but I would add it looks like it's designed to fit a lathe toolpost and hold a gear blank above the spindle height so a gear cutter can be held in the spindle. The part projecting down under the two hex headed bolts at the top looks toolholder sized.
                #638612
                Les Geds
                  @lesgeds96641
                  With you stating that, It was attached to a tool holder.
                  #638618
                  noel shelley
                    @noelshelley55608
                    As others have said, a simple dividing head. By changing the gear wheel a different division is generated. Often uses change wheel gears from a lathe. I have a similar tool but with 2 other spindles to use up to 3 gears for compound trains. Noel.
                    #638697
                    Les Geds
                      @lesgeds96641
                      Thanks everyone for the information given, well appreciated.
                      #640108
                      Will Robertson
                        @willrobertson16447
                        As well as a home-made general purpose divider my guess is that it would be handy as a quick, home-made way of cloning any given gear that could fit on the left hand side – guessing that the precision wouldn't be wonderful – it looks like that pin is spring loaded rather than being threaded to lock in place – but might have been enough for some things.
                        #640116
                        Nigel Graham 2
                          @nigelgraham2
                          Could well have been made for a specific lathe, using that machine's own change-wheels.
