Posted by Hopper on 29/05/2019 08:46:49:
Does ordinary carbide tooling cut HSS without problems?
Yes, although the cutter isn't going to last for ever. Basic cutting parameters are similar to turning hardened steel, ie, high speed, shallow depth of cut and high feedrate. I don't rough by mill that often as I have a large selection of pre-used HSS blanks, so I can usually find something close to what I need. Here's a HSS blank machined on a CNC mill with a 6mm uncoated carbide endmill:
The cutter was for shaping an internal gear so I wanted an exact profile, as drawn in CAD. Milling is especially useful for grooving tools where you need to take a substantial amount off the width of the blank – it would take for ever with a grinder.
