Dismantling a Verdict dti
Home Forums Workshop Tools and Tooling Dismantling a Verdict dti
  • #372501
    Mike Crossfield
      @mikecrossfield92481
      I have an ancient Verdict lever dti which I use a lot. Unfortunately it has become sticky, with a dead band at the end of the scale. I am losing about 30% of the scale travel. I have taken the side cover off (one screw) and it’s clear that the scroll which disappears into the back of the scale is sticking at one end of its travel. I can’t see how to dismantle the gauge any further in order to get at the offending bits. Can anyone advise?
      Mike Crossfield
        How does it come apart?sticky
        #372502
          Mike Crossfield
            Michael
            Interesting to read the original patent application, but it doesn’nt give any clues as to how to open my unit up.
            #372510
            Mike Poole
              @mikepoole82104
              I think the thread rather than the link is helpful, go to page 1 of the link Michael provided.
              mike
              #372515
                Posted by Mike Crossfield on 20/09/2018 20:00:41:
                Michael
                Perhaps you could post some photos of your unit … There are several slight variations on the theme, so actual dismantling procedure may vary a little.
                AJS
                  @ajs
                  Doubleboost has recently had a series of videos on his website of different dti's being dismantled and serviced.
                  #372601
                  mechman48
                    @mechman48
                    Posted by AJS on 20/09/2018 23:40:44:
                    +1 Doubleboost has made a couple of videos of his mate Bob carrying out overhauls on different DTI's, he's up to video # 3, iirc
                    George.
                    #372684
                    Mike Crossfield
                      As I said in my original posting, my Verdict gauge is a lever type. The doubleboost videos all relate to the push action variety, which work completely differently.
                      I’ll try to take some photos to make things clearer.
                      #372738
                      Mike Crossfield
                        Went out to the workshop with the intention of taking some photos, but in the course of playing around with the dti some more I realised what had caused the problem and fixed! It! A little while back I removed the two finger pivot adjusting screws in order to clean and degunge. What I’m pretty sure happened without me realising it was that the other end of the now-loose operating arm was able to slip out of engagement with the helix. When things were put back together the arm engaged with the helix one turn along, at a position where there was very little preload. Moving the operating arm one turn of the helix along has put everything right.
                        I’d still be interested to know how the dial part of the gauge comes apart!
