Cutting gauge glass to length
Home Forums Beginners questions Cutting gauge glass to length
  • #127196
    Mike Gibbs
      @mikegibbs79177
      I'm getting close to finishing my Polly Engineering O&K, and need to trim (~10mm) off the gauge glass provided for it to fit. Any suggestions on ways to perform this cut? I do have a lathe (Myford speed 10) and an old diamond scribe, also Minicvraft drill accesories.
      Thanks
      Mike Gibbs
        @mikegibbs79177
        #127197
        jason udall
          @jasonudall57142
          If you have one shot only…diamond saw on dremmel or the like…if you have plenty to practice with ..notch with file/scribe and snap..but just trimming. .I would saw..idealy wet but definitely eye protection and dust control.
          #127201
          Sub Mandrel
            @submandrel
            For a neat cut, wrap in paper and hold gently in 3-jaw chuck. Use a suitable tool to make a sound scratch around the glass. This is easier than trying to make an accurate circular scratch by eye.
            merlin
              @merlin98989
              I don't know whether the glass supplied is the soft soda glass or harder Pyrex borosilicate glas but whatever, keep it cool ie don't give it the opportunity to crack and chip due to overheating.
              #127205
              julian atkins
                @julianatkins58923
                a nick with a triangular file then break in the fingers.
                cheers,
                julian
                #127232
                Mike Gibbs
                  @mikegibbs79177
                  Thanks gentlemen. I will report back on the "outcome"!
                  #127241
                  maurice bennie
                    @mauricebennie99556
                    Hi Mike . Never make the cut all way round ,only a third will be better. Put the mark on top,bend glass down and pull at same time. If you have a diamond tile cutter that will do it but more trouble.
                    I have broken many tubes the first way and no problem .Was a lab tech for many years
                    Good luck Maurice
                    #127243
                    Russell Eberhardt
                      @russelleberhardt48058
                      If you only want to cut a small section off the end it is difficult to snap it after scoring. Never tried it myself but I have seen a professional glassblower cut tube by scoring it, wetting the scored line with saliva, and then just touching it with a red hot glass rod. The thermal shock does the work.
                      Russell.
                      #127290
                      nigel jones 5
                        @nigeljones5
                        I mark a line with pen then run round it on the bench grinder, light abrasion, then snap by hand. Never failed me yet.
                        #127293
                          If you have one of the DIY electric wet diamond tile cutters they will whizz through it
                          #127294
                          Sub Mandrel
                            @submandrel
                            Drill a close fitting hole in a wooden block, hold block in a vice insert the short end in the hole, and push free end down.
                            jason udall
                              @jasonudall57142
                              The snap at notch solutions are quick and clean.
                              But but did you get it right the first time you tried it?.
                              And on the one piece of tube you have?
                              Sawing it is not failure free but I think will give this chap the one off result needed…
                              #127301
                              MICHAEL WILLIAMS
                                @michaelwilliams41215
                                Whatever method you use for actual cutting be sure to dress the ends of the tube afterwards . Sharpe edges and micro cracking can cause lots of problems with premature glass failure and with damaged seals .
                                Lots of ways – tube in lathe and wet slipstone works well but best method is have a searing hot Bunsen flame and just touch the tube ends to it and let cool naturally .
                                Make a couple of spare glasses .
                                MikeW
                                Edited By MICHAEL WILLIAMS on 19/08/2013 19:45:54
                                #127302
                                jason udall
                                  @jasonudall57142
                                  Yes Michael..but does he have spare tube or just enough..but defo dress the ends..my pref. Flame polish…
                                  #127330
                                  merlin
                                    @merlin98989
                                    When breaking glass tubing or rod be sure to pull it apart as you snap it.
                                    For flame-polishing, a laboratory Bunsen burner flame is about as large and as hot as you want to go because with more heat things will happen too quickly and over too large an area. The flame is soft and easily deflected by a draught eg if someone is walking about nearby. This would not be good for the glass or for your hand.
                                    Rotate the tube end two or three inches above the top of the flame to warm it up slowly. There is a real possibility of a little bit of hot glass flying off, so wear eye protection. Make sure that you can see the end face that you want to melt.
                                    Gradually lower the end – only the end – into the hot spot in the flame. As soon as you see the very end beginning to soften and smooth out return it to the hot air above the flame, still rotating, and let it sit there for half a minute or so then gradually lift it out of the hot air. The actual softening of the end will take only about 5seconds depending on the flame source. If you leave it 'cooking' for too long it will soften too much and melt back and develop a fat ring around the end, inside and out, which will somehow have to be ground off if you want a consistent o.d. Or perhaps you use forgiving O-rings?
                                    Don't hurry the slow cooling: just letting it quench in air straight from the flame will introduce invisible strains in it and make it more sensitive to shock and liable to crack later.
                                    This gentle heating and cooling are not quite so important if it is Pyrex-type glass, but then that wouldn't easily soften in a bunsen.
                                    #127334
                                    Springbok
                                      @springbok
                                      Quite a few years back on this forum their was a thread on this subject and one of the answers was to heat it up a bit of wire to cherry red and quickly wrap it around the glass let all cool and the glass will snap.
                                      Bob
                                      #127349
                                      Mike Gibbs
                                        @mikegibbs79177
                                        OK – I "measured twice and marked once" where the cut needed to come. I put the tube, wrapped in paper, in the chuck of my lathe. Tightened just enough to grip. I then set up a carbide tool tip in the tool post and VERY gently brought it in to contact with the rotating tube. Good clean line scored in the glass. Wet the line with saliva and tapped it with a light hammer. Not a perfectly clean break, with about an eigth of the circumference breaking beyond the line in to the work piece. No problem given the pipework configuration. Gauge glass now safely installed on the backhead!
                                        RESULT! Thanks guys.
