Paul
Have you looked at the site I referred to in my initial post on this thread. You can plumb in the cutter diameter, albeit in imperial, and then it will give you a suitable RPM to cut at for a given material. For different free machining carbon steels the site gives an RPM range from approx. 53 to 200 depending on steel type for the size of your cutter. As the milling table doesn’t give a carbide speed it is assumed that the figures given are for HSS and this would agree with general guidance given by Hansrudolf. If you are getting problems with finish or you feel that its knocking too much then I would try taking a lighter cut.
Another point to bear in mind is how sharp is your milling cutter because that can affect finish and smoothness of the cutting action. A blunt cutter will definitely cause the machine rattle and produce a poor finish.
Hope this helps
Martin
Edited By Martin W on 03/04/2011 00:05:40
Edited By Martin W on 03/04/2011 00:07:07
Edited By Martin W on 03/04/2011 00:21:14
