Good new year to everyone .
Have had plenty of time in the workshop lately and I'm admitting to myself
I have three problems with the Fortis .
#1
I need to get the lathe sitting better on the concrete floor(any suggestions welcome ) .I'm toying with the idea of making a plinth for the lathe to sit on using self level cement or something the same .Possibly using rubber matting strips (4mm thick) between the bottom of the pedestals and the floor then bolting down firmly not super tight (again I'm open to any ideas ) . .The cast iron pedestals the lathe sits on only have 3 bolt holes ,2 in the head stock end (front and back) and one on the tail stock end . My first thoughts were to turn a set adjustable feet, but I'm not sure if it would work with just the 3 mounting points .I've read in a few places the reason for only the 3 mounting points is so the lathe can find it's own footing so to speak .
http://s1259.photobucket.com/user/Fortis64/media/20161106_111752-800x450_zpsdhqdvhn4.jpg.html?sort=3&o=0
Anyways that's my dilemma regarding the mounting/fixing of the lathe .
#2
The counter shaft/pulley is not running as true as i would like ,it's causing a slight vibration and because the lathe is not sitting perfect it's effecting the finish on the parts I'm turning ,more so on longer parts when using the tailstock .
#3
Tail stock is out of alignment ,I'll need to sort #1 & #2 before i can adjust it ?.
Other than that I've been having a great time messing about with the settings/speed feeds,big cuts ,very light cuts (dusting) ,using the 4 jaw more and more (great bit of kit ) really well made also . Anyone made an adaptor to use their cordless drill on the top slide for cutting tapers . I made one yesterday ,the improvement on finish is well worth the effort to make it
Sean
Edited By sean logie on 04/01/2017 10:08:25
