Copper Plating
Copper Plating
Home Forums General Questions Copper Plating
Viewing 12 posts - 51 through 62 (of 62 total)
  • #454435
    nigel jones 5
      @nigeljones5
      After soaking a great many boilers in my Suphuric acid bath pretty much everything I put in there comes out with a liberal coating of copper without any additional charge being added. It can make an old manky boiler look like an absolutely new one after a couple of days! I have a plating bath and over the years have plated lots of things. A mistake many people make is too many volts and amps. Low volts, low amps and plenty of time works for me. I used to use an aquatium water heater to help things along but turns out thet arent acid proof for long.
        Posted by Chris V on 26/02/2020 14:28:59:
        What should I then use to degrease before pickling again, methylated spirits, turpentine??
        Washing soda?
        Neil.
        #454495
        Chris V
          @chrisv
          Thanks Neil, good to have several options!
          Chris.
          #454511
          Dave Halford
            @davehalford22513
            Chris,
            From your original post I suspect many platers still in business exist to plate taps etc and as such don't plate with copper, just nickel and chrome. What you would need is someone who does car bumpers, but I have not seen one who offers a postal service.
            Don't forget plating is only as good as the finish you start with so your item will need to be mirror shiny to start with.
            #454514
            Tim Stevens
              @timstevens64731
              If you are plating with a copper electrode on one side and the workpiece on the other, the solution (of coppoer sulphate) will stay as it is during the process, so you can bottle it and use it next time. Using anything else (such as a paint brush) will have two effects – first the copper in the solution will become impure as metals from the brush etc are dissolved, so it won't work so well next time, and secondly, the plating will not be pure copper and so might not stick or look pretty.
              Use distilled water (or de-ionised – eg from a dehumidifier) and avoid contacting the solution with anything metal (except pure copper) for best results. Do not, eg, use an old kitchen spoon to measure out the crystals; a plastic spoon is OK though.
              Finally, do not use too high a voltage – best to use a charger or a torch battery, at 3 volts. 12v might look quicker but will it stick?
              Cheers, Tim
              #454530
              Chris V
                @chrisv
                Thanks Tim, more good tips and yes i'm going to try next with 2 x 1.5v batteries.
                Cheers
                Chris.
                #454659
                Howard Lewis
                  @howardlewis46836
                  If you are using primary cells, use hte biggest that you can get. But even D cells may not last too long before becoming exhausted.
                  Might be better to strap several together in series /parallel to give 3 volts and a gretar capacity.
                  #454769
                  Chris V
                    @chrisv
                    Thanks Howard, yes my plan is to link 2 together,
                    Cheers
                    Chris.
                    #454779
                      Posted by Chris V on 29/02/2020 17:30:38:
                      Cheers
                      Chris.
                      Primary cells are pricey: From 'Solved examples in Electrochemistry – Example 10'
                      0.2964 g of copper was deposited on passage of a
                       current of 0.5 ampere for 30 minutes
                      Not much copper will be deposited by a D-Cell! An ordinary Alkaline cell is about 1.5 Amp Hour capacity, meaning it will deposit about 1.8g of copper spread evenly over the immersed area, and cost about £2. (Actually unlikely to empty the battery because the voltage will drop as it discharges.) Could get expensive if it takes several attempts to get the process right and a decent thickness of copper is wanted. Electricity from a power supply is much cheaper – mains electricity is about 13p per kWHour, enough to electroplate at 1000A at 1V for an hour.
                      Edited By SillyOldDuffer on 29/02/2020 18:14:43
                      #454786
                      Jouke van der Veen
                        @joukevanderveen72935
                        Chris,
                        Go to PF Products Finishing (pfonline.com) and search there for copper electroplating.
                        They give a lot of information about plating conditions. Also for plating in a copper sulphate electrolyte.
                        You find there parameters like concentration, voltage and current density.
                        #454818
                        Joseph Noci 1
                          @josephnoci1
                          Yet another one..
                          Chris V
                            @chrisv
                            Thank you S.O.D.
                            Yes I can see that (&poundand am grateful for all the advice from everyone even with some of it conflicting! (-:
                            Having bought plugs and another wall wart and failed, probably for many reasons, my next try will be with batteries as advised by others as battery holders are already ordered. If I get some sort of positive result then mains power will be the next step.
                            Thank you Jouke & Joseph.
                            Ive looked over both links, the first rather went over my head but I'm picking tips up all the time.
                            My new container will have 7 ltrs of de-ionised water to take both the parts I'm wanting to plate together. Power will be a choice of 1x AA battery or 2x AA. There will be more space between the items and the annode.
                            Ive yet to figure out how much crystals I should add to start off with?
                            Cheers
                            Chris.
