Copper Plating
Copper Plating
Home Forums General Questions Copper Plating
Viewing 25 posts - 1 through 25 (of 62 total)
  • #452536
    Chris V
      @chrisv
      Can anybody recommend please any copper plating companies that are happy to take on small one off like jobs at a reasonable cost?
      It does not matter where in the UK as happy to post the parts.
      Cheers
      Chris.
      Chris V
        @chrisv
        Copper Platers recommendations?
        #452546
        John Baron
          @johnbaron31275
          Hi Chris,
          You can copper plate steel quite easily yourself. Just buy some "Copper Sulphate" dissolve in water and submerge your part.
          In the old days it was a nuisance if you forgot and left your tweezers in the solution, by the following day they had started to get a copper coating. You can electroplate it as well using the same solution.
          Edited By John Baron on 16/02/2020 18:54:51
          #452552
          Chris V
            @chrisv
            Thank you John, that's most interesting.
            I don't suppose there's such a simple sounding soloution for copper plating on copper?
            It's to disguise a silver soldered repair.
            Cheers
            Chris.
            #452566
            John Baron
              @johnbaron31275
              Hi Chris,
              That is a good question ! I've never considered whether copper would plate onto copper. I imagine it would, but you probably wouldn't be able to see it other than on a different metal.
              Just as a point of interest, printed circuit etching, where the copper is etched away using ferric chloride, the solution that remains contains all the copper that is removed. I've seen that solution used to electroplate steel and then used to have chrome plated onto that. So that could be a second method that you could use. But beware that ferric chloride will very quickly eat any copper it gets into contact with when disposing of it ! So don't pour it down the sink. I used to get rid of mine by soaking wood chippings with it and then binning the fairly dry residue.
              A thought has just occurred to me, you could use a paint brush to try it on a small part of the item you want to plate.
              Edited By John Baron on 16/02/2020 20:59:39
              #452573
              Paul Lousick
                @paullousick59116
                Electro Brush Plating is a method of applying a metal coating to smaller areas using a brush/wand and an electric current.
                Steviegtr
                  @steviegtr
                  Any chrome platers should do it for you. It is part of the chrome plating process on most materials.
                  Steve.
                  #452591
                  Joseph Noci 1
                    @josephnoci1
                    Posted by John Baron on 16/02/2020 20:57:06:
                    Hi Chris,
                    Just as a point of interest, printed circuit etching,………
                    And it is precisely in that industry where large scale copper on copper plating takes place.
                    To make through hole plated boards,the PCB is is first dipped in a catalyst, dried, and then into an electroless copper solution, which deposits copper onto the board and into the non-conducting through holes. Then normal electrolytic copper plating thereafter.
                    The electroless solution was always tricky – a bit of foreign material, dust, etc would set the darn thing off and it would plate out into the container within hours!
                    Joe
                    #452600
                    John Baron
                      @johnbaron31275
                      Hi Joe, Guys,
                      Thanks for your interesting post. I always thought that they used tiny hollow rivets for through holes !
                      Now I know.thumbs up
                      #452617
                      Chris V
                        @chrisv
                        Good morning all and thank you for these comments.
                        Yes Steve I'm aware most platers copper plate first, however Ive generally had bad experiences with commercial platers.
                        John you got me thinking, well Googling a little, and its something I will try at home. The utube clips & available home kits I looked at all used batteries but from the sound of it you just left the metal to be plated in the soloution and waited for it to do its thing?
                        I will have to do some more research but am keen to have a go if its not too complicated.
                        Cheers
                        Chris.
                        #452635
                        duncan webster 1
                          @duncanwebster1
                          I suspect the method without a power supply relies on the different electrochemical potential between iron (from the steel) and copper
                          Iron has a potential of -0.04, copper -0.36, silver -0.69, so I suspect you'll have to use some power. Of course this might be complete tosh, but it will then flush out someone who really knows
                          #452661
                          Jouke van der Veen
                            @joukevanderveen72935
                            you can plate steel with copper in a copper sulphate solution but the process stops as soon as all steel surface is covered with copper. The process is an exchange of iron ions going into solution and the more noble copper ions deposit on the surface. You get only very thin layers, prior cleaning is essential and adherence is not so good. So, it a not an electroless plating process in which the process continues after complete coverage, e.g. like electroless Ni(P).
                            Plating with copper in copper sulphate could be used to check if a cleaning process or pickling process of steel is good enough. If cleaning is not OK you may get a stainy copper coverage. Of course this test is done on cleaned test samples and not on the parts to be coated in a next step.
                            As Duncan just said!
                            Edited By Jouke van der Veen on 17/02/2020 12:48:24
                            Edited By Jouke van der Veen on 17/02/2020 12:49:44
                            #452662
                            Joseph Noci 1
                              @josephnoci1
                              Posted by duncan webster on 17/02/2020 11:14:10:
                              In the Electroless Copper plating method for PCB's, the plating solutions are typically a Copper suphate solution with sodium hydroxide (trace qty) and glyoxylic acid as a reducing agent. A monoamine is then used as an accelerator to kick off the plating process – no power involved in this process. This process is almost always only used to provide a very thin conductive layer on the material, and thickened up by normal electrolytic plating.
                              Your idea of different electro-potentials must be valid though – having also played wit copper iron saturated Ferric Chloride solutions, wiping a rag, soaked in the stuff, across clean steel, left a visible copper sheen..
                              Joe
                              #452710
                              Chris V
                                @chrisv
                                Ok many thanks, I shall investigate further kits with batteries!
                                Cheers
                                Chris.
                                #452763
                                John Baron
                                  @johnbaron31275
                                  Hi Chris, Guys,
                                  I don't think that I would bother with buying a kit ! All you need is an old wall wart and some suitable solution. Either some copper sulphate from a chemists or some ferric chloride and a bit of copper tube to dissolve in it. Since it seems that a paint brush connected the right way round, I can't remember if it should be positive with respect to the item you want to plate, dipped in the solution will do it.
                                  #452832
                                  Chris V
                                    @chrisv
                                    Hi John,
                                    Thanks for this.
                                    Google tells me an old wall wart is what we plug into the wall socket and then into the blood pressure monitor to convert from 240v to 6v, presume thats what you mean? The 6v end has a moulded plug, presume this would need splitting into two? cable leads?
                                    Copper Sulphate yes on eBay no bother and cheap enough.
                                    You lost me after that though?
                                    I'd want to dip my parts to be plated.
                                    Cheers
                                    Chris.
                                    #452835
                                    Chris V
                                      @chrisv
                                      Ah, just found an adaptor to fit on the end that you can plug two individual cables into, and its 12V not 6v.
                                      Chris.
                                      #452845
                                      John Baron
                                        @johnbaron31275
                                        Hi Chris,
                                        Yes that will work, as would any low voltage source. Old type car battery charger, computer PSU etc.
                                        Sorry if I wasn't clear about the paint brush !
                                        One wire would be soldered to the metal bit on the paint brush and the other would go to the workpiece. Dip the brush in the solution and use it to paint the copper onto the part. You do have to get the polarity correct though.
                                        If you are dipping the whole part into a solution then you would use an electrode placed in the tank and the other connection to the work. The electrical path is through the copper sulphate solution. Its the current flow that does the work.
                                        #452847
                                        Ian S C
                                          @iansc
                                          I would suggestyou go to the garden shop for the copper sulphate, it will be a lot cheaper than at the Chemist.
                                          Ian S C
                                          #452917
                                          Chris V
                                            @chrisv
                                            Thanks John & Ian.
                                            Ok Google also taught me what an electrode is/for, seems a bit of copper tubing will do the trick.
                                            So as I understand you if dipping the object to be plated, that will always have one wire attached to it, and the other wire to the electrode. So indirectly both + & – wires are going into the solution?
                                            If the power source is giving out 12V does that mean I'd get 12v worth of electric shock if I put my hand in?
                                            Also, does say 12V work quicker than say 3V? ( I saw one clip using a couple of batteries)
                                            Perhaps you need more Volts if the tank is holding more solution?
                                            Some clips suggest making the solution hot to work quicker I think,…. Ok but once it gets cool not sure about reheating, or if indeed that's really necessary if time is not so important?
                                            Cheers
                                            Chris.
                                            #452926
                                            John Baron
                                              @johnbaron31275
                                              Hi Chris, Guys,
                                              I had to go and Google to remember which electrode should be connected to the positive pole of the power supply ! Its the copper one in the solution. The work piece is connected to the negative wire.
                                              If you are submerging the work in the solution, it needs to be suspended so that it cannot touch anything other than the solution. Normally you would use a wooden bar or stick across the container and a copper wire connected to the negative pole to suspend the work.
                                              The stronger the copper sulphate solution is, the more quickly the work will plate. Also the more conductive the solution the higher the current for any given voltage. Using a car battery charger with a built in ammeter will give you an instant indication. Anything around a couple of amps will be fine. A useful way of getting to this point, is to make a weak solution and then add more copper sulphate until you have the current you want. Obviously you need to agitate the solution to mix and dissolve the crystals.
                                              Adding hot water will help the crystals dissolve more quickly, but as far as I am aware won't make the plating go any faster.
                                              Edited By John Baron on 18/02/2020 20:03:04
                                              #452930
                                              Chris V
                                                @chrisv
                                                Thanks so much John, I will look to order some bits at the weekend to give this a try.
                                                On a completely different subject, looking at your photos you appear to have used a yellow Tc tipped router cutter for a form tool…were you cutting steel with it on the lathe?
                                                Cheers
                                                Chris.
                                                #452982
                                                John Baron
                                                  @johnbaron31275
                                                  Hi Chris,
                                                  Yes I use woodwork carbide router bits to machine steel on both the lathe and mill.
                                                  Note the rounded shoulders on the Norman tool post pictures. They were done in a single pass at about 1000 rpm and something like 90-100 seconds an inch. I've been intending to get some cutters with 1/2" shafts, the one I have at the moment are only 1/4", and seem a bit thin for the work I've asked them to do.
                                                  I've only ever bent one and that was routing a dado edge in teak ! It bent, made a horrible vibration and then broke off at the top of the collet. Frightened the life out of me at the time.
                                                  I only started to used them because a wood router cutter is far cheaper than a form tool or a proper shaped milling cutter.
                                                  Let me know how you get on.
                                                  Best Regards: John Baron
                                                  #453037
                                                  Chris V
                                                    @chrisv
                                                    Thank you John, yes I will certainly let you know, have ordered some bits already.
                                                    Regarding that radius on the Norman toolpost ..WOW! Do you sharpen the cutters, send away or buy new when dull? I never found sending them away to be sharpened worked out, they never cut the same as when new.
                                                    Just held in the toolpost by two allen bolts then, or did you make a special holder?
                                                    Very nice toolholder you made there BTW!
                                                    Cheers
                                                    Chris.
                                                    #453046
                                                    John Baron
                                                      @johnbaron31275
                                                      Hi Chris,
                                                      That radius was simply that of the cutter. It has a small bearing on the bottom, I just wound the table in until the bearing touched and then set the depth to match the top of the work.
                                                      As far as using 1/4" inch shaft cutters on the lathe, I made a holder.
                                                      I put a piece of 1/2" square bar in the tool holder and a 1/4" inch drill in the chuck. Set the hight to the centre of the bar, making sure that it was parallel to the drill and drilled all the way through. I then just hacksawed a slit down its length.
                                                      By putting the cutter in the drilled hole and putting the bar in the tool holder and using the clamp screws to compress the bar, you avoid galling the cutter shaft which is quite soft.
                                                      Thank you.
                                                      Yes the Norman toolpost is something I should have made long ago, before spending silly money on a Dickson and three holders. You still have to prat about setting the hight when you regrind a tool. Plus it is a lot more rigid. But then I primarily only use HSS tool bits, and I'm not in a business where time is money.
                                                      Best Regards:
                                                      John.
                                                      Edited By John Baron on 19/02/2020 16:51:16
