copper boiler with dents
Home Forums Beginners questions copper boiler with dents
  • #390193
    Gerard Hengeveld
      @gerardhengeveld24288
      Hello from Canada , Happy New year to you all.
      I am new to this board and have to start with a question. Do you gent's have a inspiring idea how to remove a few small dents from the copper boiler ( stuart 504 ) I was thinking heating the dented area and shock cool it . Wrong / or stupid ? please tell me.
      Gerardthinking
      Gerard Hengeveld
        #390199
        John Paton 1
          @johnpaton1
          I have not tried to remove dents from a boiler but ….
          If the dents aren't too bad how about soft soldering a stud onto the dent and use that to pull back the dent then unsolder the stud and gently planish back any 'proud' areas and sand off any solder residue? ( a bit like the technique used to pull out dents in car bodywork)
          nigel jones 5
            @nigeljones5
            I make boilers for a living…I dont repair other peoples boilers but when I have had occasion to pul out a dent I do exactly as JP describes, you can get a car body dent removal tool off eyba cheap then machine a plug out of brass, soft solder to copper and pull out with near perfect results.
            Nigel
            Pendle Steam Boilers
            #390214
              Welcome to the forum Gerard.
              John Olsen
                @johnolsen79199
                If you want to anneal copper, you don't need to shock cool it. Just bring it up to red heat (Locally around the dent will do) and let it cool naturally. It goes very soft and nice to work.
                Jeff Dayman
                  @jeffdayman43397
                  After pulling the dent, by whatever means, I'd suggest doing a cold hydrostatic test to twice the working pressure according to the manufacturer, to verify the boiler's strength and that there are no hidden cracks or defects at the ends or along the dent, or elsewhere on the boiler as a result of it.
                  Just my $0.02 worth. Standing by for the usual disagreements and complaints.
                  #390252
                  duncan webster 1
                    @duncanwebster1
                    Posted by John Olsen on 09/01/2019 20:56:46:
                    If it was silver soldered initially it probably won't need softening. It might be worth just pumping it up as it is (with water of course) and seeing if the dent pings out
                    #390255
                    Gerard Hengeveld
                      A BIG thank you for all your advise .
                      In due course I'll let you guy's know the outcome.
                      Sincerely,
                      Gerard
