coolant pump
coolant pump
Home Forums Beginners questions coolant pump
  • #425945
    RONALD JACKSON
      @ronaldjackson50281
      Have set the Chester coolant system for my Chester db10 at lathe level,the coolant is topped up, pump working, but no coolant. Does the pump need priming ,if so how?
      RONALD JACKSON
        @ronaldjackson50281
        will not deliver coolant
        #425954
        Phil Whitley
          @philwhitley94135
          place a peice of suitable sized pipe over the coolant outlet and blow down it, if you can hear the coolant bubbling, you know the pump is immersed, and there are no bloackages, if you cant blow down it, there is a blockage, or a valve in the line somwhere which is turned off. If you can blow down it, try pouring some coolant down it and try again. is it three phase? pump running wrong way? Hope this helps!
          #426101
          larry phelan 1
            @larryphelan1
            Check that there is coolant in the tank to begin with !
            Sounds silly ? not so, been there, done that !
            If the tank is full, check that there are no valves closed and that the pump is running the right way [simple things mean a lot ! ] These pumps are usually trouble free, so it has to be something simple
            As an aside, the pump fitted to the cooling system on my bandsaw, came from a clapped out washing machine. Still working after ten years or more.
            I
            #426885
            RONALD JACKSON
              @ronaldjackson50281
              Thank you for your reply
              #426896
              David George 1
                @davidgeorge1
                Hi did you get it pumping ? If you did do you mind sharing as it helps other members.
                David
