Confused abut the oil?
Home › Forums › General Questions › Confused abut the oil?
  • #372640
    Absolute Beginner
      @absolutebeginner
      HI All,
      I am sorry to ask such a basic question but I have finally taken delivery of my first Lathe, A colchester Student 2500 Year 2007.
      Unfortunately, I cant seem to get my head around the correct oil to use. The user manual suggests DTE Extra Heavy amongst others but the lubrication diagram points towards the headstock, but it is unclear, as the diagram also seems to indicate A Energy HLP 37 toward the same place, which I assume is the two oil filler spouts when the headstock cover is removed.
      Is there anyone who might be able to point me in the correct direction please?
      Kindest regards
      Gary
      #26196
      Absolute Beginner
        @absolutebeginner
        Colchester Student 2500 Lathe YR2007
        #372645
        Chris Evans 6
          @chrisevans6
          I ran a Colchester Triumph 2000 when at work, same sort of lathe just a bit bigger. It was happy with ISO 32 in the headstock and ISO 68 for slideways. Leaked like buggery so always had fresh oil.
          #372650
          Alan Waddington 2
            @alanwaddington2
            Agree with Chris on all counts, including the incontinence……….Student 1800
            #372659
            Thor 🇳🇴
              @thor
              Hi Gary,
              No experience with a Colchester as new as yours, but on an old one from the nineteen seventies we used ISO 32 hydraulic oil (Shell Tellus) for the headstock and ISO 68 way oil (Shell Tonna) for the rest, same as Chris used.
              Thor
              #372743
              Jon
                @jon
                Theres various grades of Shell Tellus, like Harrison same group similar spec for head stock relates to Hydraulic 68.
                Slides you can feel the drag using 68, i use 32 for that.
                #372744
                Muzzer
                  @muzzer
                  I'll complete the permutations. On my Bantam I use ISO32 for both the gearboxes and the slideways, as recommended in the manual.
                  Murray
                  #372776
                  Jon
                    @jon
                    Much newer lathe the Student 2500 which shares some parts as Harrisons as the 600 Group since at least 1970.
                    Mine specifies Shellus 33 on the flip down cabinet which translates to hydraulic 68 as above.
                    https://petroleumservicecompany.com/shell-tellus-33-cross-reference/
                    Along the same line it lists other oils namely Castrol AWS 68 which is hydraulic 68 with anti wear properties.
                    Older Harrisons it translated to ATF fluid (red) which is still a form of hydraulic oil with additives.
                    #373030
                    David Standing 1
                      @davidstanding1
                      Gary
                      Why not just go to the horse's mouth, and ask the manufacturer? smiley
