Complete Beginner
Complete Beginner
Home › Forums › Beginners questions › Complete Beginner
  • #66122
    Ryan Lack
      @ryanlack22024
      Hi there,
      I am a complete novice in all respect of model engineering, that means: no background knowledge on how to weld, cut or machine materials aside from some school experiences. I have always loved railways and models and so looking to the live steam hobby it has become one of my life goals to build a steam locomotive. Now I am still young (18 years) and will be entering a mechanical engineering course after I leave school. I have recently become quite interested in the 3.5 gauge Northumbrian as it is fairly cheap and has simple workings. I was wondering if i were to purchase the casting and components set as well as the machinery required what sort of prerequisites should be met before I begin?
      Thanks,
      Ryan
      #5460
      Ryan Lack
        @ryanlack22024
        A question on where to start.
        #66123
        David Clark 13
          @davidclark13
          Hi Ryan
          Make sure you have up to date drawings or if using the ones in Model Engineer use the revised edition of the frame drawing.
          I would start by machining some of the components that do not require castings or expensive materials.
          When you have made some of these, consider moving on to the castings.
          If you are a subscriber to Model Engineer or the digital issues you can access the articles online.
          regards David
          #66125
          Ian S C
            @iansc
            Welcome to the world of model engineering Ryan, my machine shop training cosisted of two yrs metal work at school, then a short time in trade training in the RNZAF. After leaving the air force, i did an apreticeship as an aircraft mechanic on light aircraft. After that I spent many yrs as a Nurse until I had to retire. I took up wood turning, then I bought a vertical mill/drill, then a lathe. My first project (after making some tools for me), was to make about 20 driving/spur centers for wood lathes, in 1,2,and 3 MT, they sold well. so I made a few other bits and pieces. I then started making bits for vintage tractors, and farm machinery, I then was contacted by the local Military Vehicle club, to make parts for WW2 Jeeps, I also helped rebuild a few of them. It was only then that I started making models, mainly Hot Air Engines, no kits, no castings, made with what ever I can find. Ian S C
            #66174
            Peter G. Shaw
              @peterg-shaw75338
              Ryan,
              From one old learner to one new learner. There are but three rules:
              1. Don’t hurt yourself. Machinery can be replaced: you cannot.
              2. Someone else, ie not me, said: “No question is too stupid if you do not know the answer”. So, take a tip from someone who is still learning, and making mistakes: Ask, ask, and ask again. Despite the occasional person who seems to think they know more than everyone else, there is a lot of very helpful and knowledgeable talent on this forum.
              3. Enjoy yourself.
              Regards, and good luck,
              Peter G. Shaw
              #66177
              Niloch
                @niloch
                I urge you to try this.
                #66178
                Niloch
                  @niloch
                  As well as this.
                  #66179
                  James B
                    @jamesb
                    Hi Ryan,
                    Might be worth having a look at Tubal Cains book ‘ Simple Model Steam Engines’ – written from a complete beginners viewpoint, will guide you through all operations – some machining, some boiler work, some sheet metal, and assumes a limited equipment.
                    The book provides all drawings, and the engines are made from stock materials – no castings. As well as getting some experience, you get a finished model quickly to spur you on.
                    I found it excellent when I was starting, and am now starting to build another with my son for him to learn on.
                    Good luck!
                    James
