HI Bob, there are three windins in a three phase motor, usually labelled A B and C. The winding connections are marked A1 and A2. B1 and B2 and C1 and C2. Connect A1 to B2, B1 to C2 and C1 to A2. You now have the motor connected in delta. Connect one phase to each of the three junctions and test. If the motor runs the wrong way reverse any two of the incoming supply leads. If this makes no sense send a pic of the motor connector, and any markings you can see on the motor leads, and the make of motor, and I will try to help.
Phil
UK
