Co2 Cartridges
Co2 Cartridges
Home Forums Beginners questions Co2 Cartridges
Viewing 11 posts - 26 through 36 (of 36 total)
  • #108867
    wheeltapper
      @wheeltapper
      Posted by Bazyle on 15/01/2013 23:35:44:
      I assume they are pretty strong so how about minirollers for moving machines.
      Meanwhile I keep wondering about a use for plastic milk bottle tops. (Bottle part cut off is a handy container)
      I discovered that they are a good fit on the eyepieces of my binoculars,laugh
      Roy
      Jeff Dayman
        @jeffdayman43397
        Further thoughts inspired by Axel's excellent ladle suggestion above:
        On steel cyls that are empty, the necked end could be cut off, the cylinder cut in half lengthwise, and a wire handle welded on to make a nice firing shovel for small models with a round or oval firedoor. The hemisphere shape of the back end might be easier to get back out the door opening if it went in too far and dropped. The flat backed ones can be a pain to get back out. Front corners can be radiused to suit.
        Just food for thought.
        JD
        #108880
        Bob Lamb
          @boblamb44747
          Bazyle asked earlier fo a use for plastic milk bottle tops. I was just about to throw one away – not sure if the tops are re-cyclable here- when I thought they would be ideal for mixing small quantities of flux with water. I usually use a yoghurt pot or similar and always end up making too much – hopefully this will result in less waste in the future – Bob
          #108927
          Sub Mandrel
            @submandrel
            I would guess the cylinders are made of aluminium
            All the small cylinders I have used are steel.
            I have both
            thomas oliver 2
              @thomasoliver2
              Surely these are still used to operate small CO2 engines for indoor model aircraft like the Gasparin, Telco etc. These motors are provided with a clip-in mounting for these cartridges. Offer them on the BMFA website. You might get a bob or two for them. TomOl.
              #109018
              nigel jones 5
                @nigeljones5
                Why not paint little faces on them and stand them in your workshop to scare away all the goblins and pixies that come in the night and move/steal your tools?
                #109690
                Speedy Builder5
                  @speedybuilder5
                  I have some plans for a model gas turbine which uses empty CO2 cartridges as the ignition chambers. Each has a glow plug in them and the motor revs at around 30,000 revs. Never got round to it because of the problems in making the compressor and turbine rotors.
                  Bob
                  #109718
                  M0BND
                    @m0bnd
                    I can acquire a few from my gun club if any body needs some? In the weymouth area!!!!
                    #109771
                    Ian S C
                      @iansc
                      Bob, one of the earlier gas turbine models, made by a German chap ( ??Schekling), had a centrifugal impeller made of plywood, I think I would try recycling the innards of an old automotive turbo charger.
                      Ian S C
                      #109777
                      thomas oliver 2
                        @thomasoliver2
                        The wooden impellor worked since it was in a flow of cool air, and was a lot easier to make than milling from a solid piece of tough metal. Turbo charger impellors from cars were widely used later, the particular one which was popular was from a Porche engine. Bearings were one big problem at the speeds and the temperature involved. The use of ceramic bearings was the big break through. TomOl
                        #109790
                        Joseph Ramon
                          @josephramon28170
                          The gasparin adapters use the smaller sparklet sioze, not airgun size.
                          Joey
