Enough here to scare the living daylights out of any beginner; myself included. That's a pity.
I think the basic problem for newcomers to machining is that it is difficult to visualise the difference between 'climb or hook' milling and conventional or ordinary milling when you are standing in front of the machine. Even some of the 'great and the good' seem unsure when viewing the picture that started Neil off on this theme! The confusion is compounded because most of the printed diagrams seem to portray the processes on a horizontal milling machine, a type a lot less familiar to most of us than the vertical variety.
All that said, Graeme W is probably correct when he suggests an article on this subject is not warranted. Given the premise that a (good) picture is worth a thousand words, if you look selectively, you can find superb explanations of the operation on YouTube and I am going to provide three links.
The first is to Erik Vaaler. For those not already acquainted with Mr Vaaler, he provides a wide range of professional quality videos presented using utterly sound and safe techniques in a crystal clear format. The section on climb milling is in 'Machine Shop 7 Milling Machine 4'. Come in at 17 minutes if you must, but most of us will benefit from the whole episode and, indeed, all his other offerings.
For a more homely approach, though none the less clear, try 'John' in 'How Not To Climb'. Come in at 29 minutes for climb milling including
simple diagrams anyone can understand.
Finally, if you are troubled by scarey slitting saw dramas 'call up' Erik, or 'Tom' in 'Monday Night Meatloaf (don't ask me why his series has such a stupid title) 15'. Apart from both experts showing safe use of this potentially brutal device, Tom explains for beginners what saw you need for what task. Thus, don't use a blade with multiple teeth if you want to saw stock in half, this tool is for delicate jobs such as producing an immaculate screwdriver slot. If you want to saw per se, use a blade with a small number of large teeth. Nobody told me that!
After watching John I wrote in my notebook NEVER CLIMB MILL except for a very very light finishing pass. Seems fair enough.
And after watching Erik and Tom I wrote on slitting saws:
NEVER FIT THE ARBOR KEY
GO AS SLOW AS YOU CAN
USE LOTS AND LOTS (FLOODs) OF COOLANT/LUBRICATION
TAKE LIGHT CUTS
STOP, WITHDRAW AND CLEAR THE CHIPS FREQUENTLY
NEVER EVER CLIMB MILL.
Fair?
All the best one and all. Martyn
