I purchased a large quantity of Morse taper drills, for a modest sum. The drill sections are all fine, even sharp!
However, some of the MTs have had a hard life and have the usual dents and dings on them. Having cleaned up my MT sockets on the lathe, I am loathe to use some of the worst offending drills in them.
Can I simply put them in a three jaw chuck and set up the top slide with a DTI and get the correct angle (obviously on a good example!). Then I could take the merest smidgen of a cut to remove anything that rises above the MT taper surface? I don't intend to do anything but clean up the high spots.
It sounds fine to me, so what have I missed, nothing seems to be as simple as it appears!
Andrew.
