Cleaning acid etch primer off brushes
Home Forums General Questions Cleaning acid etch primer off brushes
  • #25416
    Rainbows
      @rainbows
      Rainbows
        @rainbows
        Been repainting a new to me Record 25 vice. Used Zinc Phosphate acid etch primer for the first coat followed by zinc phosphate primer for the follow up coats.
        Issue is white spirits won't clean my brushes of the etch primer. Works fine on the other primer but I can foresee a pile of stiff paintbrushes forming in the near future.
        What should I be using to clean this stuff off?
        #310541
        Anonymous
          Use cheap brushes and bin them afterwards.
          #310542
          not done it yet
            @notdoneityet
            There are several thinners/paint removers which would do the job. The item is clearly not oil based, so try a cellulose or universal paint thinner. Plenty on the net or from suppliers, I would think. Even Li*l. Look on the tin – there may well be a list of the sovent or suggestions for cleaning brushes.
            Might even be water!
            Edited By not done it yet on 05/08/2017 17:45:10
            #310550
              I buy the thinners for the paint from the same place I get my etch paint.
              Why not look up the makers web site for your particular brand and see what they suggest.
              Edited By JasonB on 05/08/2017 18:29:49
              #310562
              Mikelkie
                @mikelkie
                I do what Andrew J does. Thinners, paint remover and cleaning agents are to expensive to waste on relatively cheap paint brushes, not to mention the waist of time cleaning them.
                #310565
                Michael Topping
                  @michaeltopping17870
                  I use spray gun cleaner, available from eBay relatively cheaply, it is good for cleaning air brushes too.
                  Michael
