Posted by Jon on 18/10/2015 22:46:58:
Regarding tool system of choice ER any company worth its salt doesnt use ER where time is money.
Many other systems are favoured notably Emluge, Tormach or the back locking types with double the ER force and types that are quick release with a reference built in so cutters can be swapped over retaining tool heights.
A few points.
Firstly the Clarkson / ER argument will always run on, it's akin to metric v imperial / do you turn to a calculated diameter before knurling / can you make sense of Ady's screw cutting charts [ delete as required ]
If you have an equipped workshop and a supply of cutter sufficient to last then the Clarkson will fit the purpose very well. I used then for years.
However if you are at the stage of starting up then one of the ER series is well worth contemplating for a few reasons.
[a] It's both a work holding and tool holding option so one set of collets and one or a face mounted lathe chuck with give you access to use on a mill and lathe.
[b] Secondly they are no gaps in the holding range, each one, with exceptions on the smaller sizes covers a 1mm range. The very small sizes cover 1/2mm.
[c] There is no difference between imperial and metric so 4 collets 7-6, 10-9, 13-12, and 16-15 can hold eight sizes of popular cutter 6, 10, 12 and 16 plus 1/4", 3/8", 1/2" and 5/8"
They can also securely hold any size drill up to maximum you can throw at them.
[d] Many modern cutters are now being made with no threads and most importantly the shank sizes are the cutter sizes so a modern 5mm carbide cutter is usually on a 5mm shank. Something a Clarkson cannot handle.
Steamer earlier queried how a cutter can movce once it's on the centre pip.
The answer is when the cutter tightens up it forces the collet down into the nose and for every action there is a reaction. Even though it is on the pip it's only hand tight and the forces will force it to be pushed back harder onto the pip. It is this uncontrolled movement that causes cutters to break, whereas when you tighten with a small gap the operator decided the clamping force and not the sudden uncontrolled movement.
The answer Jons original quote where he mentions the Tormach system.
I am very, very surprised he mentions this as which being a quick change system it has many drawbacks. Foe a start it's base on a holder fitting into an R8 taper so for a start you have two sources of run out, the Tormach holder and the R8. Both of which are lacking in rigidity.
Users of the system admit that it's possible to overload it and the fact that it's not suitable for any system greater than 2HP says a lot.
Martin quoted
"The tightening sequence of Autolock collets is widely misunderstood."
which should read.
"Some of the information on Wikipedia is widely misunderstood" As after all it's an unregulated book of personal opinions.
Edited By John Stevenson on 19/10/2015 12:16:33
