Chinese tacho – beware
Home Forums Manual machine tools Chinese tacho – beware
Viewing 25 posts - 1 through 25 (of 46 total)
  • #13567
    duncan webster 1
      @duncanwebster1
      duncan webster 1
        @duncanwebster1
        Many years ago I made an electronic tacho for my lathe, using a design I got from somewhere forgotten in the mists of time. It used a PIC programmed in very arcane code. Works fine, but as it updates very very quickly the last digit flickers, and the display is a bit dull. When I fitted VFD to my milling machine I had to make my own tacho as the only sensible pulley to fit the sensor went at a different speed to the main spindle. That updates more slowly and is OK. Decided eventually to sort out the lathe one, and bought a Chinese tacho, no point making one at that price. Problem is the update rate is so slow it's difficult to adjust the spindle speed. OK if you just want to know what speed it's doing, but when adjusting by the time it updates you've gone way past. Original is now back in place, the new one can wait till I need to just measure rather than adjust something.
        Of course I should have just plugged it in before making a very nice box for it to sit in!
        #415222
        Former Member
          @formermember32069
          #415224
            Posted by Barrie Lever on 20/06/2019 15:08:11:
            I feel it is no co-incidence that all of the broken pieces of equipment in my workshop are from the PRC.
            If you have an iPad … Just be careful to not take that into your workshop devil
            I.M. OUTAHERE
              @i-m-outahere
              Posted by Michael Gilligan on 20/06/2019 15:32:21:
              Or just about any other electronic device !
              Duncan ,
              Did you consider using an Arduino to make your new Tachometer?  – plenty of sketches available and  adjusting the update frequency is simple enough .
              Edited By XD 351 on 20/06/2019 15:48:53
              #415238
              Former Member
                @formermember32069
                #415239
                  Sorry, Barry … I was just teasing
                  Logic:
                  Statistical analysis would find two commonalities between the broken items in your workshop:
                  1. They were all made in PRC
                  2. They have all entered your workshop
                  I have no way of knowing which, if either, is causative.
                    And the third, you bought them because they were cheaper than a quality brandwink 2
                    #415244
                    Former Member
                      @formermember32069
                      #415245
                        Former Member
                          @formermember32069
                          #415252
                          Ron Laden
                            @ronladen17547
                            Barrie, probably produced for Fluke, most of the top mobile phones and cameras are made in China, like you suggest they can equal the best in the world but like top quality from any part of the world you have to pay for it.
                            #415261
                            John Smith 13
                              @johnsmith13
                              I bought a WEN variable speed drilling machine with the same issue that the tacho takes several seconds to catch up with what's happening. I could live with this but the quill is such a sloppy fit that the drill bit blurs at high speed making it unusable for accurate work. I didn't get chance to use this before the 3 month warranty expired. I can see a major rebuild in its future or trip in a skip!!!!
                              Former Member
                                @formermember32069
                                #415268
                                duncan webster 1
                                  @duncanwebster1
                                  Duncan ,
                                  Tacho on milling machine is driven by Arduino, it updates 4 times a second. Some of the code is my own work, but as with many Arduino projects you cab crib bits from other stuff o the interweb
                                  #415278
                                  john carruthers
                                    @johncarruthers46255
                                    Fluke.
                                    Fluke have 3 factories, 2 in PRC and one in Germany.
                                    The Fluke multimeters are tested and callibrated on an instrument made in Deal, Kent, codename 'Baldrick'.
                                    Each factory has 2 such testers.
                                    The main problem in manufacture is the fake parts in the supply chain.
                                    Even the PRC guys get caught out.
                                    #415322
                                    old mart
                                      @oldmart
                                      I have Kennametal carbide inserts made in the USA, UK, Germany and China.
                                      #415333
                                      ronan walsh
                                        @ronanwalsh98054
                                        Quite a lot of the large motor manufacturers such as mercedes, BMW etc, have factories in China to make components, or complete cars for those regions. Triumph motorcycles are touted as being made in England, but again a lot is made abroad, Malaysia and India i believe, frames, suspension components, switchgear etc. The design and engines are made in the UK.
                                        So saying anything is rubbish because its chinese, or made in the far east is fraught with danger.
                                        #415338
                                        Frances IoM
                                          @francesiom58905
                                          The Fluke multimeters are tested and callibrated on an instrument .. codename ‘Baldrick’.
                                          I guess anything that passes this must be a fluke (always thought they had picked a very poor name for a supposed accurate instrument)
                                          #415339
                                          Clive Hartland
                                            @clivehartland94829
                                            When I had the Ford Granada, 3 times I was stranded because the cut off fuel solenoid failed. By this time I always had 2 or 3 spare in the car. I had one examined and x.rayed and it showed that a bunch of wire was sealed at the top of the solenoid, it was made in Mexico. A long phone call with Ford after sending microscope images elicited that they would replace it for me. Strangely after that I had no more incidents.
                                            #415342
                                              Posted by Barrie Lever on 20/06/2019 16:25:59:
                                              You are a wise and learned man, can you name me 5 Chinese brand names in mainstream retail? No meaning or agenda in the question.
                                              Interesting question…
                                              Lenovo and Huawei for a start.
                                              Reg Wortley
                                                @regwortley
                                                Take a look at this **LINK**
                                                I have used two of these, the first on my Optimum lathe, laterly have one fitted to my S7.
                                                Paired with a VFD its something I would not want to be without.
                                                The S7 reads the teeth on the Bull gear and gives consistent readout.
                                                Reg
                                                #415353
                                                  Posted by NZreg on 21/06/2019 00:02:03:
                                                  Thanks for that, Reg yes
                                                  I did look, and quickly found: **LINK**
                                                  http://www.machtach.com/BuyOff.html
                                                  …. but was pleased to see that the Docs are still available.
                                                  MichaelG
                                                  #415378
                                                  Cabinet Enforcer
                                                    @cabinetenforcer
                                                    Posted by Neil Wyatt on 20/06/2019 23:44:06:
                                                    Add Pirelli to that list. Xiaomi are not yet that big in western retail, it won't be long before they are though. Haier sell some own brand stuff, but also own brands including sanyo and candy. Hisense were one of the main world cup sponsors and sell TVs worldwide.
                                                    #415381
                                                    Former Member
                                                      @formermember32069
