With a DRO, look at what you are requiring from the unit. Some have a much nicer and user friendly interface than others. If it is just to pitch holes and replace the normal dials on a machine tool any dro will do. If you want to cut curves, or put a row of holes on an off square axis, then look for a dro that has the lines of information that will show a radius value or and inclined layout. Some cheap dro that have these sort of features are like this one.
**LINK** You will have to do a search for the tech-3i manual. Anyway one feature I do like about it is the Radius feature for the odd job that does not require the resetting of a rotary table. My kit came with the 5um glass scales and are very happy with it. There are cheaper units, but I have not seen a cheaper one with the data line.
Most will have the reference thingy in them for if the power goes off and the axis is moved while the power is down. This will set back the reference again, assuming you used it to start with.
The one I really liked the best is from Newall DP1200, but that unit and scales is work more than my mill, but is really user friendly, and has a great graphic interface when the tool is approaching the zero point etc. It is what is on the lathe at work.
