Cheap alternative to replacement Record hardened jaw plates?
Home Forums Workshop Tools and Tooling Cheap alternative to replacement Record hardened jaw plates?
Viewing 6 posts - 26 through 31 (of 31 total)
  • #192844
    john carruthers
      @johncarruthers46255
      Like many others I use ally angle or copper pipe opened up for soft jaws. The annoying thing is when the eventually 'curl up' from use.
      My vice was also a foundling missing its hard inserts. The remaining jaw part was chopped off flush, and tops straightened up with a 10" grinder.
      Might invest in a good vice one day.
      Rik Shaw
        @rikshaw
        I'll go along with the gauge plate for replacements. That is what I fitted to my milling/shaping vice and just skimmed the top edge with a fly cutter to finish them of. If you go careful they need not be hardened.
        Gripped – sorted!
        Rik
        #192901
        Howard Lewis
          @howardlewis46836
          Can only agree with all the advocates for gauge plate, hardened or otherwise.
          My experience of magnet retained Aluminium soft jaws is that they don't stay retained for very long. Then I hammered over the top and ends to retain them. They stay in place when gripping, but fall off as soon as the jaws are opened. NOT good for blood pressure or temper, but keeps the back supple picking the…………things off the floor or bench!
          Fibre jaws don't grip as well, and soon get mangled. I have a new boxed set on the shelf that I can never bring myself to use, for that reason!
          #447772
          Peter Love 1
            @peterlove1
            Hi I have just sent back to a supplier on Ebay a set of 4 1/2" jaws for my No 4 Record, they were 4 1/2" long but not 1 inch wide Record/Irwin, so I need the original type before Irwin came on the scene anyone know were I can obtain a pair ?.
            Peter.
            #447783
            Oldiron
              @oldiron
              Posted by Peter Love 1 on 20/01/2020 13:27:25:
              Peter.
              This is an old post Peter. You may have to trawl round some of the old Record vise stockists in the hope they have original old stock still on the shelf. Searching several forums the same question seems to come up now and then with no real answer. As many people say you can make your own soft or hard jaws. Is it possible to turn the old jaws over and put the clean bottom face to the top ?
              regards
              #447785
              larry phelan 1
                @larryphelan1
                I have a 6" Record vice some 46 years old and thought about getting new jaws for it until I saw the price ????
                Needless to say, that,s as far as I went ! They are mad money, so I will think about mild steel or gauge plate, even if it has to be smooth.
