I'm glad the belts and they torque they can give cropped up. It seems that there is a retailer around that might say buy a 2,800 rpm motor to get a 2,800 rpm spindle speed, throw other pulleys and any gearing away and set what ever speed is needed via the inverter. If only.
I haven't done my mill but have changed my lathe. I did what a lot of people do upped the motor power. This means that I can reduce speed and still have the same torque at the cutter as I did have. It can give a reasonable speed range. This subject often crops up elsewhere and some one said it's wonderful and posted a video where the inverter was used to bring the speed right down. It's an excellent example of when extremes may work out. He drilled a sizeable hole with the inverter at 50Hz, this took some time. He then changed the cutter to a sort of fly cutter to face the area around the hole and then brought the speed right down with the inverter and used it which took seconds so there was no chance of burning out the motor due to the cooling being reduced. I've always wondered what happens if a separate fan is fitted as the inverter will control the motor current. Mitsubishi inverters will model the thermal behaviour of the motor which should help but for their own motors. They also have a random switching setting which does a lot to remove the noise problems this type of drive has.
It is possible to get motors that are intended to be driven over a wide speed range. They usually have a fixed speed fan and are balanced for higher speed running and are costly. I asked Brooks about running at high speed and got the answer that he doubted if they made an 1400 rpm armature that would have problems running at 2,800. Wont burst in other words. TEC show how they think their motors should be run on their inverters in one of their catalogues if it can be found. This should give people an idea what ordinary motors can do. One of the catalogues doesn't provide any data at all.
I went from 1/2 to 1hp on my lathe. In part because I had let some of the smoke out of the 1/2 hp a few but there was still enough smoke left in it to allow it carry on working after it had cooled down. As I was making the change I also fitted the inverter. I generally run it at 40 to 80Hz but mostly up to 60Hz. I'm in no rush when I work so didn't change belts that often anyway.
