Champion No 1 sensitive drill (made in England)
Home Forums Manual machine tools Champion No 1 sensitive drill (made in England)
Viewing 25 posts - 1 through 25 (of 25 total)
  • #89337
    Dennis WA
      @denniswa
      I have just acquired this from a friend. Does anyone know who made these?
      Thanks
      Dennis
      Dennis WA
        @denniswa
        #89339
        Ady1
          @ady1
          I will have a wild stab at this
          http://www.championcuttingtool.com/_index_home.html
          #89346
          Dennis WA
            @denniswa
            Champion Cutting Tool is a long-established American firm – my sensitive drill is UK-made, with a big 1950's style label "Champion No 1 Made in England"
            #89348
            Terryd
              @terryd72465
              Hi Dennis,
              There was also a Champion machine tool company in the United Kingdom, although I have no information about them. I'm not sure if they were related to the US company of the same name or completely independant. Sorry not to be of more help.
              Terry
              #89350
              Dennis WA
                @denniswa
                Terry…Tony's http://www.lathes.co.uk/ lists Champion UK in his " incomplete list of Manufacturers and Brands" – there is no other information.
                Dennis
                Edited By Dennis WA on 19/04/2012 10:56:03
                #89352
                Terryd
                  @terryd72465
                  Hi Dennis,
                  I came across this, not much but at least a picture smile. The pictured machine reminds me of one I had in a school workshop used as a point of interest and discussion. Couldn't use it due to unguarded rotating bits.
                  Terry
                  #89356
                  IanT
                    @iant
                    Modifications to the 'Champion' 1/4" drill were described by 'Duplex' (probably in ME but haven't found the issues) and I'm pretty sure it was a British product. I have the Duplex "In the Workshop" volumes (published in 1951) and (in volume 3) Duplex descibes the Champion as a machine "which has been widely used for many years past".
                    The modifications by the way are to increase the speed range. They also describe a similar mod for the 3/8" Cowells drill – one of which I happen to own (but have not so far modified).
                    IanT
                    #89373
                    Terryd
                      @terryd72465
                      Posted by IanT on 19/04/2012 12:15:22:
                      Modifications to the 'Champion' 1/4" drill were described by 'Duplex' (probably in ME but haven't found the issues) and I'm pretty sure it was a British product…………….
                      IanT
                      Hi Ian T,
                      The article which I think you are referring to is in issue 2508, p 548, 1949, vol. 100.
                      Terry
                      #89378
                      Dennis WA
                        @denniswa
                        Thank you Terry and IanT for your feedback.
                        The link to Champion (Machine Tools) in Graces Guide shows a picture of the drilling machine – it is identical to the one I have acquired, which, after removing some surface rust on the exposed steel column etc, is in very good condition.
                        Fortunately I have old MEs from 1939 onwards ( bought cheaply many years ago) and following up on your leads there are the ME articles by "Duplex" in issue 2500 (pg 478) and 2502 (pg 548) of Vol 100 (January – June 1949) dealing with extending the speed range of a 3/8" Cowells and a 1/4" Champion drilling machine.
                        As IanT quotes, they write on page 479, " …the 1/4" capacity Champion drilling machine, which has been widely used for many years past, …." I assume that these machines must date at least from the 1920's onwards?
                        Back to my question – does anyone know where Champion (Machine Tools) had their factory?
                        Many thanks
                        Dennis
                        #89407
                        michael cole
                          @michaelcole91146
                          I have a nice one of these drills. I under stand it was home build from a set of castings.
                          #89422
                          Dennis WA
                            @denniswa
                            Looking at the 1949 Vol100 ME they were advertised by tool merchants for Eight Pounds Five Shillings (presumably without motor)!
                            #89579
                            MICHAEL WILLIAMS
                              @michaelwilliams41215
                              Hi Dennis ,
                              Champion drilling machines were made by :
                              B.Elliot & Co.Ltd.
                              Victoria Works , Willesden , London NW10 .
                              There were at least three models – called simply models 1 , 2 , 3 .
                              I have a quarter page ME review of the model 3 if you want to see it .
                              Regards ,
                              Michael Williams .
                              #89586
                              Terryd
                                @terryd72465
                                Hi Michael,
                                are they the same Elliots who made the larger bench and pillar drilling machines?
                                Best regards
                                Terry
                                #89589
                                MICHAEL WILLIAMS
                                  Hi Terry ,
                                  C.B.Elliot became Elliot Machine Tools .
                                  Under various trade names they manufactured , factored , badged in and badged out seemingly hundreds of types of machines . They also bought several other companies and continued their product lines as well .
                                  Best known trade names :
                                  'Elliot' as such . There are Elliot industrial lathes , mills and drills including radial arm drills .
                                  There was also the Elliot variant of the BCA series mini jig borer .
                                  'Selecta' for small machines like grinders . They also made the original forerunner of the Unimat as the Selecta Universal Machine Tool .
                                  'Victoria' used mainly for milling machines .
                                  'Cardiff ' – some absolutely superb lathes where made under this name in a subsidiary factory at Taffs Wells north of Cardiff . Building is still there .
                                  'EMT' seems to have been used as a random alternatve to the full name .
                                  You can pick up a bit more of the historical trail here : http://www.lathes.co.uk/elliott%20mini%20jig/index.html
                                  Regards ,
                                  Michael Williams
                                  #89593
                                  Dennis WA
                                    @denniswa
                                    Hi Michael..
                                    Thanks for your comprehensive answers!
                                    Which ME contained the review of the model 3? (As indicated in an earlier post above, I have bound volumes from 1939 onwards)
                                    Dennis
                                    #89594
                                    MICHAEL WILLIAMS
                                      Hi Dennis ,
                                      Model Engineer Vol. 106 No.2657
                                      Thursday April 24 1952 pp546/547
                                      Regards ,
                                      Michael Williams .
                                      #89618
                                      Dennis WA
                                        @denniswa
                                        Hi Michael…
                                        Thank you for the prompt response!
                                        Dennis
                                        #102777
                                        MICHAEL WILLIAMS
                                          #102784
                                          Harold Hall 1
                                            @haroldhall1
                                            IanT and Dennis both mention the Cowells drilling machine, have a look here for a photo of one I made, complete with the speed range modification. This was supplied as three castings with the major machining already done. However, as a teenager I could not afford them so asked if I could purchase the raw castings, completing the task on a Myford ML4.
                                            Incidentally, Cowells still exist, and in the same premises in Watford as they did 61 years ago. Unfortunately, they no longer supply the casting kits that they did then, one of which was a very nice hand powered shaper, see here . Does anyone reading this still own one?
                                            This is not the same company who presently make small lathes and milling machines.
                                            Harold
                                            #102787
                                            Mark C
                                              @markc
                                              That is a coincedence! I have one of these that I "rescued" from the local recycling center – I had no idea it was a little brother to the two Elliot mills I have. I will take some pictures and upload them when I get a moment.
                                              Mark
                                              #102803
                                              Gone Away
                                                @goneaway
                                                There are hand operated shaper castings available from Martin Model in the US (I'm in Canada so it's not quite the shipping problem it would be in the UK). I've considered something like this a few times but wonder how much physical effort is required. Does anyone have any direct experience in that regard?
                                                #102814
                                                Mark C
                                                  @markc
                                                  turns out mine is a number 2 – the motor is out of the arc, probably an old hoover washing machine or the like!
                                                  #102828
                                                  IanT
                                                    @iant
                                                    Sid – wrt your question about hand shapers.
                                                    I have an Adept No 2 hand shaper – and it's not really the physical effort (I only take small cuts anyway) but more the time it takes – it gets a bit boring. So it is a device that in some ways is better used for smaller items where the area you are machining isn't that large – not because you can't machine larger stuff – but because it simply takes more time. Very small slots/ways are also possible with simple tooling that's easy to sharpen.
                                                    Having said that – if the mill is already set up for something else – then some jobs still get done on it and I can get a very fine finsh with very simple tools. I also intend to make some tooling for line engraving – both on dials and flat surfaces. Another use could be keyway slots in bores – I'd probably do this on the Adept shaper rather than make a dedicated slotting attachment – easier/quicker.
                                                    So in summary a very useful device to have – especially for smaller items where my larger mill would be a bit too large, or where setting up on the vertical slide might be a bit of a pain (or I've got other stuff already in progress). I think it could also be used in a variety of other ways (with a little thought) where a controlled linear cutting motion is required.
                                                    Ian T
                                                    #102883
                                                    Gone Away
                                                      @goneaway
                                                      Thanks, Ian that's useful info. The shaper who's casting set I was referring to is necessarily limited to small jobs (4" stroke, 4" traverse). My main problem is that health related issues over the last few years have left me a bit down on muscle mass in my arms so a manual machine is a bit of a query.
                                                      Truth be told though, I'm more interested in the making of the machine than the using of it smiley
