Hi all,
A little off subject here, but knowing the range of experience between you all I thought it was worth a punt:
I have just fitted a Drayton RTS9 room stat, 4 wire connection, (L,N COM & CALL) with an indicator light. When fitted the indicator light was on when the room was calling for heat whether the system was programmed on or off. I preferred to have the indicator light lit only when the heating was programmed ON and calling for heat. I removed the permanent live and replaced it with a link from the COM as this is only live when the programmer switches on the heating. This is working OK but I have noticed that the indicator light glows dimly when the heating is programmed off and not calling for heat, does anyone know, is this to be expected?
