Centering microscope
Home Forums Workshop Tools and Tooling Centering microscope
  • #375505
    Gray62
      @gray62
      Having sourced a Beck teaching head, I am now constructing the centering microscope as described in MEW 272.
      I need a graticule but the ones from Hemingway are a bit pricey. Having looked on ebay, and a few other places, I can't find one that is small enough, most are over 20mm in diameter. Does anyone know of a source for these ?
      Gray62
        @gray62
        looking for a graticule
        #375509
        Emgee
          @emgee
          Mitutoyo but they won't be cheap.
          Emgee
          #375513
          Martin Connelly
            @martinconnelly55370
            iGauging may have somthing that suits.
            Martin C
            #375514
              I haven't yet read the article, but:
              1. Top quality reticles |*| are [almost] never cheap
              2. A quick search on ebay, for 'eyepiece reticle' sorted by 'lowest price + postage' found several that should be useable about £8 each.
              Out of interest: What exactly is Hemingway selling, and at what price ?
              |*| https://www.pyseroptics.com/graticules/microscope-eyepiece-reticles/
              Edited By Michael Gilligan on 11/10/2018 18:23:54
              #375526
              Gray62
                @gray62
                Posted by Michael Gilligan on 11/10/2018 18:21:08:
                The Hemingway graticule is a crosshair with concentric circles, approx 17mm dia and £34 + p&p which in the grander scheme of things is not horrendous but, it represents a significant outlay when compared with what the rest of the parts cost me.
                #375548
                  Might be worth getting one of the combined eyepiece/reticles as they only cost about a pound more. Not sure if they are adjustable though.
                    Posted by NLP on 11/10/2018 20:09:24:
                    If you need one with circles, then this one seems reasonable: **LINK**
                    https://www.ebay.co.uk/itm/Microscope-Eyepiece-Micrometer-Reticle-Concentric-Circles-Calibration-1X-2X-4X/323270458650
                    If you can manage without circles … I found one at £3.20
                    https://www.ebay.co.uk/itm/Microscope-Objective-Stage-Micrometer-Calibration-Slide-10mm-100-0-1mm-C7/262480477627
                    [ it's not very well described, and comes from a seller with zero feedback, but it may be a bargain ]
                    P.S. Neil makes an excellent point … but I very much doubt they are adjustable for centration.
                    Edited By Michael Gilligan on 11/10/2018 22:11:21
                    #375573
                    Gray62
                      @gray62
                      Michael,
                      thanks for those links, Think the first one will fit the bill as it's only 16mm diameter which will be perfect for this application.
                      cheers
                      Gray
                      #375837
                      John Reese
                        @johnreese12848
                        You could go "old school" and use spider silk for the crosshairs. I believe silk from the Black Widow spider was the preferred material.
                        #375839
                        Clive Hartland
                          @clivehartland94829
                          I was waiting for someone to come up with spider web. First catch your spider and put him in a box on his own. Then you starve him ! why, because when he craps it is attached to the web like a round object. After starving for a while get the spider onto a wire frame, wind the web he issues around the frame spaced apart so you can lay the strand across the cell where you want the cross wires. Fix in place with shellac.
                          Some backgrounnd, spidere web graticules absorb the shock of recoil in the telescope on the artillery piece. Mostly used on coastal artillery. All superceded now by etched graticules or photo etched and coated. One time they were drawn finely on beeswax on the surface of the glass and placed over an open mouth of a bottle of Flouric acid. Nasty!
                          #375840
                            Posted by John Reese on 13/10/2018 22:32:13:
                            But unless the spider is uncommonly co-operative, it's unlikely to produce the circles that Gray would like.
                            angel MichaelG.
                            #375848
                            Mark Rand
                              @markrand96270
                              Just weigh his clogs down on one side, so he walks in circles?
                              #375875
                              daveb
                                @daveb17630
                                Posted by Clive Hartland on 13/10/2018 22:53:25:
                                Yes! That's exactly how I did it nearly 60 years ago but we used to buy the web ready wound on cardboard frames. I always checked to make sure there were no spiders in the box. I should think the web winding trade has died out by now, so if you need to do this, you will probably have to catch you own Black Widow. I believe it needs to be female, they're a bit bigger than the males. Daveb
                                Edited By daveb on 14/10/2018 11:00:38
                                #375984
                                Mick B1
                                  @mickb1
                                  I knew they were used in telescope graticules, but not gunsights. I think it will be because that was the easiest way to make them. In point of fact the recoil shock on an artillery piece has lower g-force than small arms – muzzle velocities are in similar ranges and the barrel length, and therefore time, for acceleration are very much greater. The snap of a good air-rifle's spring piston bottoming imposes the most severe reticule shock of all – scope creep and even breakage has required specialised design effort to resolve.
                                  Added to that, artillery scope sights are generally mounted on the fixed carriage, further decoupling the shock.
                                  #375996
                                  Clive Hartland
                                    @clivehartland94829
                                    I would look at this as an old time method, as said earlier the technique of making fine graticules was not developed and as Artillery telescopes were of a medium power big fat scored graticules filled with black were not accurate enough.
                                    Making the grat. from spiders web gave a very thin graticule which suited the application fine..Consider that in older guns the gun was bore sighted using horse hair across the muzzle and the telscope aligned with it by looking through the barrel from the vent tube. Targets were church steeples or any other well difined object more than 400 yards away. Nowadays they set up a big board with the sighting marks on the board for the bore and the telescope and even the small bore weapons. Any minor adjustments are then made on the range. Thats why i am deaf!
