Without reading back up to 5 pages, what is the current motor shaft diameter, how much could you remove from the pulley for a sleeve? Would boring the pulley remove the current keyway? Is it a one horse power motor?
I found plenty of larger diameter twin sheave pulleys available but when I looked they were all of larger diameter. Not quite so important with variable speed motor control, I suppose (I overlooked that at the time).
If it is the motor/pulley at fault, the motor mounts may be ‘adequate’. Out-of-balance issues can exacerbate/exaggerate mounting shortcomings.
There are normally 4 long bolts holding both ends of the motor casing to the stator part of the case. Sometimes long bolts, sometimes studding with nuts at each end. Bearings are usually fairly easily removed from the end caps or warming (gently) assists, particularly if the end caps are aluminium. Generally need a bearing puller to remove the bearings from the motor shaft. Mark where everything fits to make rebuilding easier.
It is not difficult to fabricate a bearing puller for these types of motor – a piece of plate to slide over the shaft behind the bearing, a couple of suitable length bolts and another plate with two holes for the bolts and a central threaded hole for a further bolt to draw off the bearing.
The non-drive-end bearing is almost always the better of the two (if money saving). If bearings are dry, lubing may possibly work (but bearings are relatively common and cheap). Out of balance running could have destroyed the bearing. If changing bearing(s) don’t buy the cheapest. I nearly always go to my local stockist (ABC) for belts, bearings, etc.
For this application, fully sealed bearings would suffice, doing away with the need for further lubrication, but bearings with one side sealed would enable future lube, generally by grease gun. Sleeve bearings are unlikely, but would be lubed either by gun or a felt wick.
Edited By not done it yet on 09/08/2021 09:14:49
