Car problems
Car problems
Home Forums General Questions Car problems
Viewing 25 posts - 1 through 25 (of 104 total)
  • #25315
        Yesterday I accelerated hard up to 60-70 to overtake a lorry after leaving a roundabout, the car pulled well, but when I changed up, there was no 'drive'.
        Basically the clutch feels normal, and I could select any gear but the engine just raced as if in neutral. There were no nasty bangs, no strange noises afterwards.
        I managed to coast to a slip road and the AA got me the 42 miles home (only taking 10 hours and a change of pickup) from 4pm to 2 am.
        It all seems to sudden to be clutch wear, the web is full of 'it could bes' but I need some advice of deciding what problem it really is, I can see three possibilities;
        • Gearbox has stripped splines or teeth on final drive.
        • Drive shaft snapped
        • Diff has popped its clogs.
        • Clutch has stripped its drive splines or the pad material has had a catastrophic failur
        Anyt advice on deciding which it might be? I need to figure out if its a write off, expensive job or a DIY (probably only the drive shaft)
        Jonathan Garside
          @jonathangarside40968
          What make and model is the car and current mileage would be helpful.
          Not saying I can help but others with similar cars may be able to
          Jonathan
          #303306
          Hacksaw
            @hacksaw
            Get over to Autoshite forum , ask them . They'll have it sussed and fixed within the hour !
            #303307
            DMB
              @dmb
              1 Dump AA
              2 Find new, much cheaper breakdown outfit – some do home start and roadside for £40+
              3 Hope jamjar goes better now
              RRMBK
                @rrmbk
                Not up to speed on modern cars but had a not dissimilar problem on a tractor where the central splined section of the clutch plate broke away from the friction disc. No obvious nasty noises but the friction disc was spinning with the flywheel but had no connection to the gearbox input shaft which remained static. One test might be to see if the car can be rolled back or forward whilst engaged in gear. good luck.
                #303309
                David Jupp
                  @davidjupp51506
                  Had something similar on a front wheel drive Vauxhall – it was just a circlip dislodged that allowed the first motion shaft to retract from the clutch (as per design when changing clutch without removing gearbox).
                  Really need to know make/model, or at least FWD / RWD…
                  #303310
                  ChrisB
                    @chrisb35596
                    Check the gear linkage or cable, could have disconnected in neutral and give you the symptoms you mentioned
                    #303311
                    not done it yet
                      @notdoneityet
                      What does the gear stick do? If it is a PSA gearbox, it could be the selector mechanism. Had two that failed in the same mode. Cheaper to change the box than repair, in my case (high mileage and box needed to come apart for new expensive bits in an older vehicle), as a second hand box was easily sourced. Unfortunately the replacemment went the same way.
                      #303314
                      David Standing 1
                        @davidstanding1
                        Ten hours to get home? Super Adept Man could have flown that in a nanosecond!
                        But seriously, per post #2, more details of the car required smiley.
                        #303317
                        Hacksaw
                          @hacksaw
                          Does Neil drive a Mitsubishi Space wagon?
                          #303318
                          John Stevenson 1
                            @johnstevenson1
                            Pretty sure he has a Mondayo
                            #303322
                            Speedy Builder5
                              @speedybuilder5
                              Oh you can't go to heaven in an old Ford car,
                              Cos an old Ford car won't get that far……
                              BobH (Austin 7)
                              #303327
                              peak4
                                @peak4
                                I don't know much about modern cars, but I'll have a guess at a blown CV or a circlip popped off a driveshaft allowing it to disengage.
                                Any pools of oil underneath?
                                #303328
                                Hacksaw
                                  @hacksaw
                                  You can in a Ford Orion..
                                  #303335
                                  Gordon W
                                    @gordonw
                                    Well I'll have a guess at broken prop-shaft , no noises etc.
                                    #303336
                                    David Standing 1
                                      @davidstanding1
                                      Posted by Gordon W on 20/06/2017 10:51:43:
                                      That'd be interesting, it's FWD if it's a Mondeo wink 2.
                                      #303338
                                      Cornish Jack
                                        @cornishjack
                                        It's obviously caught the 'gearbox disease'!!sad I speak with authority since my Berlingo auto, having operated faultlessly and parked at home, won't engage ANY gear in auto or manual although engine starts perfectlysurprise. A bit premature with only 8k on the clock! Called local main dealer where car was bought – £300.00 to recover to them, THEN the bills start!! Now searching locally for a cheaper recovery deal.
                                        I hope your problems will be simpler (and cheaper ) to fix, Neil.
                                        rgds
                                        Bill
                                        #303339
                                        ega
                                          @ega
                                          Neil's AA experience contrasts strongly with their current advertising but worse things happen: yesterday I was told about an acquaintance who set off to drive the seven miles from north London to a central location for dental treatment allowing two hours for the journey; arriving ten mnutes late, they were told they could not be seen that day!
                                          Good luck with the car – a broken halfshaft on an Austin Seven could have been fixed at the roadside.
                                          #303341
                                          Gordon W
                                            @gordonw
                                            Well, live and learn. How do FWD get the power to the wheels ? Now I see– prop shaft / half shaft.
                                            #303344
                                            David Standing 1
                                              @davidstanding1
                                              Posted by Gordon W on 20/06/2017 11:18:33:
                                              Gordon
                                              The generally accepted terminology is with RWD – prop shaft and half shafts; with FWD – drive shafts.
                                              #303345
                                              Juddy
                                                @juddy
                                                I would guess at a gear selection cable having become disconnected or even broken
                                                #303349
                                                  If I remember rightly AA will only tow withing a certain area so in Neils case he was spread across two and had to change tow trucks.
                                                  RAC will tow all the way with one truck.
                                                  Just hope Neil can print the spare part once the fault is located
                                                  Edited By JasonB on 20/06/2017 11:34:06
                                                  #303367
                                                  simondavies3
                                                    @simondavies3
                                                    Posted by RRMBK on 20/06/2017 09:27:00:
                                                    …but had a not dissimilar problem on a tractor where the central splined section of the clutch plate broke away from the friction disc. No obvious nasty noises but the friction disc was spinning with the flywheel but had no connection to the gearbox input shaft which remained static.
                                                    Had a very similar experience with a car with an overdrive – the shock of the O/D engaging ripped the spline section from the clutch plate material. No noise apart from a slight tinkling but no drive either. Box out, replace clutch – not sure if they do that to modern cars though!
                                                    #303380
                                                      Thanks.
                                                      High-mileage Mondeo, manual, although the clutch was changed no more than 40K ago when the engine was swapped.
                                                      Unfortunately one of the hardest cars to swap the clutch in, as you virtually need to drop the engine right out.
                                                      Looks like clutch isn't engaging drive shafts seem to be on good terms with the wheels.
                                                      Just been to dentist, despite being dropped off in Lichfield I had a long walk to get there, then long walk back, then bus, then long walk from bus stop home.
                                                      Too knackered to look at car now, going to sleep for an hour or two …zzzzZZZZ
