Broken drill bit stuck
Home Forums Beginners questions Broken drill bit stuck
  • #165621
    Wolfie
      @wolfie
      I actually got to my workbench today for the first time in ages. Picked up where I left off which was with 2 pieces of aluminium clamped together ready to be drilled through.
      The bit promptly broke around half way through the second piece and when I tried again in another hole the (second) drill broke again at around the same point.
      2 things arise from this, is there a reason they both broke in teh second piece, was I doing summat wrong??
      And how the hell do I get the broken piece of drill out of my piece of ally. Its a hole thats open at both ends but I've hammered and hammered and the bloody thing won't shift
      Edited By Wolfie on 05/10/2014 08:35:07
      #7327
      Wolfie
        @wolfie
        #165624
        Ian P
          @ianp
          An indication of diameter and size of parts involved would help. I have had similar events, sometimes when drifting broken bits of metal out they 'dig in', maybe trying to go slightly sideways and the broken bit effectively becomes embedded.
          If the proportions and the metals are amenable, brute force might punch a whole slug of the parent metal out leaving you to a change of design. (bushes, Helicoil etc)
          Ian P
          #165625
            Welcome back stranger
            Soak it in alum solution and the steel will corrode away over a day or three.
            If you ever want to keep the steel not the aluminium use caustic sode instead.
            Wolfie
              @wolfie
              Its a slab of ally about half an inch thick and the hole is 2.3mm. It was the upper of the two pieces so the hole is right through
              #165659
              jason udall
                @jasonudall57142
                To recap.
                Two slabs of ali..
                Same alloy
                1.5" thick each
                Drill breaks in upper slab before breaking through. .about half way ..ie 0.75" deep
                ..and twice at approximately the same depth…
                So my first thought was lower part moving and "scissor ing" thus gripping the drill ..
                It appears not.
                If as I have summarised its breaking in the first layer..my guess would be maybe swarf jam
                Or an inclusion in material. ..
                #165660
                  I've had similar happen when swarf pushed the two plates apart and got stuck in the gap then jamed the drill.
                  Were you drilling dry or lubricated and how often were you lifting the drill to clear teh swarf?
                  #165664
                  Eric Cox
                    @ericcox50497
                    Same happened to me last week, small diameter drill. It was caused by swarf clogging the flutes. The swarf virtually "welds" itself to the flutes and that's why you're having trouble removing the broken drill. Don't drill too far down before you remove the drill and check the flutes, take your time and check often.
                    #165665
                    Bob Brown 1
                      @bobbrown1
                      Paraffin or similar (wd40) will reduce the swarf sticking to the drill not forgetting to peck drill adding lub as you drill
                      #165667
                      Tony Pratt 1
                        @tonypratt1
                        Lack of lubrication & not clearing the swarf is the likely cause.
                        Tony
                        #165668
                        Ady1
                          @ady1
                          As mentioned, ally melts onto the cutting edge and welds itself there. I tend to use backgear for turning or drilling ally so there's not enough heat generated to cause a problem
