Since Bridges is/was an American manufacturer, I would put my money on 8 x 32 UNC.
MANY years ago, pre WW2, Morris used Hotchkiss engines, so they were metric.
The BMC A series engine rocker adjustment screws were 1/8 BSP, when the rest of the car used Unified threads. The earlier side valve engined Morris Minors, used 7/16 BSF wheel bolts. The BMC powered ones were Unified. The handbook made a point of the identification marks.
Pre WW2, C.A.V. started by making Bosch Fuel Injection Equipment, under licence, so metric dimensions were the standard. In the 50s, they bought the licence from Hartford Machine Screw to make the Roosa Master pump as the DPA, (Distributor Pump A) all drawings had to be Metric, but still use Unified threads. So the American Imperial dimensions became odd Metric ones, (1/4 inch became 6.354mm , and so on). BUT, the threads for the Injection Pipes were, like all others, Metric, (often a 14mm fine thread).
Certain Bristol buses were powered by Gardner engines which were resolutely Imperial, BSF and BSW.
The Bell Housing was retained by 9 off 3/8 BSF bolts and three 3/8 UNF studs. The Clutch went one better, 12 off 3/8 BSF bolts, to hold it to the Flywheel, but with 5/8 A/F heads!
Leyland drew a line, and all new designs changed to Unified threads, but the engines, gearboxes, and certain other parts were earlier designs, carried over onto the new chassis. So a fitter needed two toolkits to be certain. Then came the 500 Series engine which was Metric, imagine the confusion when working on the "Unified" chassis, powered by the "Metric" engine, and containing original Whit standard components!
Until recently, engines which had their roots in Imperial sizes were made to Metric drawings, (so few round figures there!) but on engines which changed to use metric fasteners in most places, certain critical threads remained Imperial, because of the massive cost of converting the tightening tooling to suit Metric fasteners. It was only when the new Designs evolved into totally metric ones, requiring new jigs, fixtures and tooling that they became truly Metric.
Remember, that the Continent use threads which they call "Gas", which are actually British Standard Pipe; Whit form threads and all!
My lathe uses metric threads everywhere, except on the Mandrel, that is 2.25 inch x 8 tpi Whit form.
My Mill/Drill with Imperial leadscrews, has a mixture of Metric and Whitworth threads; the latter for the more important ones, funnily enough!
Standardisation, where art thou?
Edited By Howard Lewis on 20/04/2016 20:30:59
Edited By Howard Lewis on 20/04/2016 20:35:15
