Thanks all for your input, but I think I may have found a way to determine the correct rotation without knackering any internals (and I can't see any rotation markings on the box or motor anywhere). My idea is to put it all back together once its cleaned and oiled and set it back on the end of the table, but leave the motor off the gearbox. Then engage the traverse lever, I should be able to reach the pinion in the box with my finger and move it a little to see which way the table moves, if it moves in the correct direction I will know which way the worm on the end of the motor must turn. To be fair as I've got the box apart I can probably trace the gear motions to work it out that way but I fear that will make my head sting. Looking inside I'm not convinced that running the motor the wrong way would do anything other than make the table go in the wrong direction but I'd rather err on the side of caution as I doubt spares are obtainable if I did faff it up.
B
