The common Dahlander connection two speed motors cannot be run off an ordinary 220 V output VFD because they don't have alternative low voltage (220 V) Delta and high voltage (440 V) Y connection capability. They require 440 V input for both speeds with the coils laid out Delta style for low and Y steel for high.
There are six windings in the motor. For low speeds the windings are connected in a series loop with power applied to every other connection. So 440 volts is applied across each pair and the individual windings see 220 volts each. For high speed the windings are connected in parallel pairs. One end of each pair goes to a common point the other end receives power. So each winding sees 220 volts.
You can run a Dahlander motor in high speed setting off a 220 V VFD by connecting the windings in parallel pairs and running them in a series loop with power applied to each corner. Effectively each parallel pair is equivalent to the single windings on a normal three phase motor in Delta connection. Not something for the novice to try. Its very, very easy to get things muddled up with paired windings out of phase or not correctly paired. Not something I'd try. I could do it but wouldn't if you see what I mean.
Wikipedia has an adequate, albeit small, diagram of the coil layouts :- **LINK** . Google search will show up plenty more pictures but most aren't linkable. This is quite a good one showing the switching involved :- **LINK** for speed changing.
Edited By Clive Foster on 01/09/2018 17:18:01
