Brass Tube
Brass Tube
Home Forums General Questions Brass Tube
  • #338663
    Mike Crossfield
      @mikecrossfield92481
      I need an 8 inch length of 2 inch diameter 16 or 18 gauge brass tube (to fill with lead for the pendulum of a clock I am making). My usual supplier of clock making brass sells CZ121 at around £2.50 per inch, but I've seen others selling 16 gauge brass steam pipe for 1/2 the price. Does anyone know what grade this would be, and if there is a snag to using it in my application?
      #25782
      Mike Crossfield
        What grade is “steam pipe”?
        #338666
        John Haine
          @johnhaine32865
          Only snag I can think of is that the grade might not be very machinable but you wouldn't be doing much of that other than maybe squaring off the ends. I'd go for it myself.
          #338693
          Bazyle
            @bazyle
            If getting it mail order be sure to mention that is to be used in a decorative role and must be free of dents. A clock supplier might be worth the extra for this and I can only think brass steam pipe must be left over from Mamod boiler making,
            You could look into rolling it from sheet.
            Edited By Bazyle on 28/01/2018 14:54:43
            #338697
            Billy Bean
              @billybean67480
              Maccmodels can supply
              2 inch diameter by 16swg – they list an 8.5 inch length at £8.39 plus post.
              Hope this helps.
              BB
              #338727
              Mike Crossfield
                Yes, Maccmodels was the supplier that triggered my question. Unfortunately they don’t state the grade of brass.op
                #338736
                Billy Bean
                  @billybean67480
                  Posted by Mike Crossfield on 28/01/2018 18:12:27:
                  The reason why I mentioned it was that I was the buyer who asked if they could supply an 8 inch length as opposed to a 12 inch length and Joe was his usual obliging self.
                  I used this tube to make a brass boiler – still going strong.
                  This is going to sound like a daft question but can you tell me why the grade of brass is important?
                  Thanks
                  BB
                  Edited to say – I have always found Joe to most helpful .
                  I am sure he would be able to tell you  the grade of brass if asked.
                  Edited By Billy Bean on 28/01/2018 18:50:07
                  #338772
                  Mike Crossfield
                    The grade matters because I will need to skim it after filling it with lead. Some grades of brass are chewy, and tear, so getting an attractive finish is very difficult. Guess I need to speak to the man at Maccmodels.
                    #338775
                    Billy Bean
                      @billybean67480
                      The tube Joe sent me polished up a treat – I just squared ends on lathe and then spun and polished – I have an older lathe just used for that purpose.
                      Sounds an interesting hobby – is there a reason why it is skimmed after filling with lead as opposed to skimming prior to filling ?
                      I quite understand why grade matters and thanks for explaining.
                      BB
                      #338776
                      roy entwistle
                        @royentwistle24699
                        Mike I always filled my weights with lead shot. You used to be able to get it from gunsmiths but I'm not sure whether you still can
                        Roy
                        #338793
                        DMB
                          @dmb
                          Roy,
                          If 12 bore cartridges no longer filled with lead shot, I wonder what on earth is used as a substitute?
                          Clive Hartland
                            @clivehartland94829
                            Steel shot or Bismuth. Barrels need to be marked for steel shot. Range is lowered for steel shot and most water shooting is now Bismuth shot. Lead kills birds by ingestion from dabbling in mud and/or being shot!
                            #338811
                            roy entwistle
                              @royentwistle24699
                              Clive How does the weight of Bismuth shot compare with lead ? ( Just out of curiosity these days )
                              Roy
                              #338813
                              John Haine
                                @johnhaine32865
                                Ditto, why would you need to skim it? Shouldn't get lead on the outside if poured carefully; it will probably tarnish but surely that can be removed by polishing?
                                #338836
                                Mike Crossfield
                                  I like to see a finely turned finish on weights and pendulums, so need a suitable grade of brass.
                                  #338838
                                  Mike Crossfield
                                    Also takes care of any minor surface imperfections.
