Brass dome cover construction
Home › Forums › Locomotives › Brass dome cover construction
  • #1367
    andrew winks
      @andrewwinks64215
      #177551
      andrew winks
        @andrewwinks64215
        Thought I'd share some very pleasing fabrication of a dome/safety valve cover for my 5" gauge Queensland Railways A-10. These are available as aluminium bronze castings but I thought it would be a rewarding exercise to machine and fabricate from solid brass round and phosphor bronze tube, both scrap "donations" to my workshop of ferrous supplies. Below, machining the top from solid brass round section.
        #177552
        andrew winks
          @andrewwinks64215
          step 2, rough out the top and fit to PB tube section.
          #177553
          andrew winks
            @andrewwinks64215
            Weld a former/spigot together to form a die to press the PB into shape. Anneal first. Simple press fabrication from angle, etc. 12 tonne bottle jack provides the encouragement..
            #177554
            andrew winks
              @andrewwinks64215
              looking OK, shape is appealing and even.
              #177555
              andrew winks
                @andrewwinks64215
                Check fit..
                #177556
                andrew winks
                  @andrewwinks64215
                  Final skim to size
                  #177557
                  andrew winks
                    @andrewwinks64215
                    Quite pleasing, close to prototype. Producing these parts is most fun one can have standing up!!
                    #177566
                    Johnboy25
                      @johnboy25
                      Congrats… Nice piece of work. Certainly looks the part.
                      Jeff Dayman
                        @jeffdayman43397
                        Great job Andrew, well done. Nice to see a good bit of presswork done in the home shop. JD
                        #177597
                        andrew winks
                          @andrewwinks64215
                          Thanks! Used a similar method to produce the petticoat for the stack.
                          The engine is running on air, boiler was completed and hydrostatic tested in 2014 (I have a bunch of pics on the boiler construction that I will post one day soon) and hope to have first steam up before mid year. Bought the castings in '97 so about time I made some solid progress!
                        Home › Forums › Locomotives › Topics
